chevyduece
#1 Posted : 15 years ago
chevyduece
when I start dryer[gas] it gets hot for about 10 minuets then cools down and won't get hot again unless you wait 15 minutes or more.All the info I have seen points to the igniter / coil area, since it gets heat isn't the igniter working to initiate the heat?
If igniter and or coils are to be replaced can someone explain how / where to locate and is it best to replace as an assy, or replace coils only.
Steve
#2 Posted : 15 years ago
Remove the plug (#49 on the diagram) and watch the igniter and flame for awhile. If the igniter glows and then goes off without the falme came on then the problem most likely is a bad coils. If the igniter does not glow at all then igniter is bad.
- The coil kit Part number: AP3094251
Steve Aslin (Refrigerator & Freezer Repair)
by Steve Aslin 13 years ago
Steve (Washer Repair)
by miste32725 13 years ago
Steve (Oven Repair (including Ranges and Cooktops))
by deepwate1r 14 years ago
Steven Cote (Refrigerator & Freezer Repair)
by Steven Cote 15 years ago
steve (Dryer Repair)
by chevyduece 15 years ago
Steve.JAS (Washer Repair)
by steve.jas 16 years ago
From Steve, Rochester MI (Refrigerator & Freezer Repair)
by Steve Taylor 16 years ago
Steve W (Washer Repair)
by swal779725 16 years ago
Steve (Refrigerator & Freezer Repair)
by Steve Douma 16 years ago
Steve Oberman (Washer Repair)
by Steve Oberman 17 years ago
by SPreuss 17 years ago
by compass69 18 years ago
