chevyduece
#1 Posted : Tuesday, October 13, 2009 1:51:52 PM(UTC)
chevyduece
when I start dryer[gas] it gets hot for about 10 minuets then cools down and won't get hot again unless you wait 15 minutes or more.All the info I have seen points to the igniter / coil area, since it gets heat isn't the igniter working to initiate the heat?
If igniter and or coils are to be replaced can someone explain how / where to locate and is it best to replace as an assy, or replace coils only.
Steve
#2 Posted : Tuesday, October 13, 2009 3:45:55 PM(UTC)
Remove the plug (#49 on the diagram) and watch the igniter and flame for awhile. If the igniter glows and then goes off without the falme came on then the problem most likely is a bad coils. If the igniter does not glow at all then igniter is bad.
- The coil kit Part number: AP3094251
Steve Aslin (Refrigerator & Freezer Repair)
by Steve Aslin 6/22/2012 3:35:11 PM(UTC)
Steve (Washer Repair)
by miste32725 4/2/2012 11:39:14 AM(UTC)
Steve (Oven Repair (including Ranges and Cooktops))
by deepwate1r 10/31/2010 12:44:21 PM(UTC)
Steven Cote (Refrigerator & Freezer Repair)
by Steven Cote 8/26/2010 5:07:55 PM(UTC)
steve (Dryer Repair)
by chevyduece 10/14/2009 3:00:58 PM(UTC)
Steve.JAS (Washer Repair)
by steve.jas 7/23/2009 4:29:41 PM(UTC)
From Steve, Rochester MI (Refrigerator & Freezer Repair)
by Steve Taylor 5/14/2009 10:25:25 AM(UTC)
Steve W (Washer Repair)
by swal779725 4/8/2009 1:43:32 PM(UTC)
Steve (Refrigerator & Freezer Repair)
by Steve Douma 3/25/2009 12:30:18 PM(UTC)
Steve Oberman (Washer Repair)
by Steve Oberman 8/11/2008 8:48:24 AM(UTC)
by SPreuss 1/14/2008 5:28:16 AM(UTC)
by compass69 8/3/2007 10:05:46 AM(UTC)
