Steve Aslin
#1 Posted : Friday, June 22, 2012 3:35:11 PM(UTC)
Steve Aslin
water will not dispence into icemaker. I bought a new icemaker installed it ( the old one did the same thing ) that is why I replaced it. I checked the water valve it was ok. ( I moved the wires from the door dispencer water valve to the ice maker valve pushed the water dispencer and it filled the icemaker waited and it dispenced the ice so I know the water valve is ok. What else could be wrong:mad:
#2 Posted : Saturday, June 23, 2012 3:00:06 AM(UTC)
Replacement parts for Maytag MFI2266AEB10 REFRIGERATOR | AppliancePartsPros.com
See the attachment for the tech sheet includes the wiring diagram and wiring routing.
You may have a bad connection between the ice makes and the valve.
Check the plugs/receptacles for a backed out pin or bad crimp.It may be a bad wire so if you cannot find anything obvious you will have to do a continuity test using a meter.
File Attachment(s):
MFI2266.pdf (394kb) downloaded 18 time(s).
