jimnlois@gmail.com
#1 Posted : Thursday, February 7, 2008 6:43:09 PM(UTC)
jimnlois@gmail.com
my washer will not agitate or spin, i have replaced the door lock switch to no avail what is next? thanks jim
#2 Posted : Friday, February 8, 2008 3:19:52 PM(UTC)
Hi Jim,
Most likely the problem is with the motor control board.
Remove the bottom panel and look for an envelope with the short service manual. Perform all necessary tests.
- Here are the break down diagrams for the Frigidaire washer Model FWT647GHS0
jimnlois@gmail.com
#3 Posted : Saturday, February 9, 2008 6:11:30 AM(UTC)
jimnlois@gmail.com
thanks gene, in step 3 i measured voltage between pins 5 and 6 and had 0 volts. does that mean that the speed control is bad? jim
#4 Posted : Saturday, February 9, 2008 12:47:01 PM(UTC)
Hi Jim,
I'm not sure because I do not have a service manual for your washer.
If you can post it or fax it to me (714.809.7679) I can tell you more specific.
mlalcala
#5 Posted : Sunday, February 10, 2008 1:01:13 PM(UTC)
mlalcala
my washer does not spin can you give me some helpfull tips please
#6 Posted : Monday, February 11, 2008 10:34:39 AM(UTC)
In order to provide the most accurate advise I need the complete model number of the washer and more specific description of the problem.
Guest (4)
GE top load washer doesn't spin (Washer Repair)
by marcobot 11/4/2020 6:47:00 PM(UTC)
Washer doesn't spin (Washer Repair)
by user21 12/8/2015 11:14:30 AM(UTC)
Recently moved washer doesn't spin (Washer Repair)
by lucymaud 3/10/2015 2:29:48 PM(UTC)
Top-loading GE washer doesn't spin (Washer Repair)
by BASSplayerACE 11/8/2014 6:28:44 AM(UTC)
Kenmore washer doesn't spin during wash cycle (Washer Repair)
by pcklbike 9/12/2014 2:20:03 PM(UTC)
Washer Doesn't spin (Washer Repair)
by Davejarm 6/19/2014 8:43:26 AM(UTC)
Maytag Atlantis Washer doesn't spin (Washer Repair)
by dave not the plumber 1/13/2014 5:17:05 PM(UTC)
GE Washer doesn't spin in spin cycle (Washer Repair)
by jglascoe1691 12/10/2013 10:22:42 AM(UTC)
Washer doesn't spin, burning smell (Washer Repair)
by PG_Chillin 10/3/2013 2:50:19 PM(UTC)
Whirlpool washer doesn't spin every load (Washer Repair)
by smitty731 5/31/2013 4:35:32 PM(UTC)
Washer doesn't spin - have all the sypmtoms (Washer Repair)
by MWarner 2/24/2013 7:42:26 AM(UTC)
Washer doesn't spin efficiently (Washer Repair)
by ffanslau 2/18/2013 1:03:30 PM(UTC)
Washer doesn't spin on high but spins on low (Washer Repair)
by WilliamC 9/17/2012 7:05:28 PM(UTC)
Washer doesn't spin or agitate (Washer Repair)
by dragz 7/28/2012 8:28:47 AM(UTC)
by bjorgvinben 6/28/2012 11:15:12 AM(UTC)
