my washer will not agitate or spin, i have replaced the door lock switch to no avail what is next? thanks jim
Hi Jim, Most likely the problem is with the motor control board. Remove the bottom panel and look for an envelope with the short service manual. Perform all necessary tests. - Here are the break down diagrams for the Frigidaire washer Model FWT647GHS0Gene.
thanks gene, in step 3 i measured voltage between pins 5 and 6 and had 0 volts. does that mean that the speed control is bad? jim
Hi Jim,
I'm not sure because I do not have a service manual for your washer.
If you can post it or fax it to me (714.809.7679) I can tell you more specific.
Originally Posted by: jimnlois@gmail.com  my washer will not agitate or spin, i have replaced the door lock switch to no avail what is next? thanks jim my washer does not spin can you give me some helpfull tips please
In order to provide the most accurate advise I need the complete model number of the washer and more specific description of the problem.
