fdb
#1 Posted : Sunday, October 11, 2009 7:37:52 AM(UTC)
fdb
frost buildup on coil in freezer. don't see a timer, The defrost element is a little blackened. What components control the defrost ? What voltage is at the heating element in normal defrost operation. What is best way to check defrost system?
applianceman
#2 Posted : Sunday, October 11, 2009 12:01:03 PM(UTC)
applianceman
I am assuming your model number starts with GSS rather than DSS correct?
If so the most common thing with will cause this is the defrost element. You can check it with an ohmmeter and if it is open replace it.
If not the thermistor near the top of the coils and the main board could be your problem.
Refrigerator repair guide
#3 Posted : Monday, October 12, 2009 3:17:32 AM(UTC)
Unplug fridg, remove the cover from the motherboard in the back and locate the three pin power connector. Remove connector, notice which pins are labled defr, and line on the pc board. Place a jumper into the mating pins on the connector. Fridg should defrost, if not, you have a bad defrost heater, if defrost, you have a bad motherboard.
lg freezer not defrosting (Refrigerator & Freezer Repair)
by richardskg 1/13/2022 12:13:59 PM(UTC)
Whirlpool Refrigerator GS6NBEXRT01 Freezer not defrosting (Refrigerator & Freezer Repair)
by Alexeyk 1/6/2020 12:04:41 PM(UTC)
Freezer Not Defrosting - Fan, Thermometer, Heater "okay" (Refrigerator & Freezer Repair)
by frankla10 3/30/2017 2:41:44 AM(UTC)
by kend64 8/13/2014 1:12:13 PM(UTC)
by poinzy82 8/15/2013 4:00:48 PM(UTC)
by RedStickBill3 8/28/2012 1:31:57 PM(UTC)
Freezer not defrosting coils (Refrigerator & Freezer Repair)
by srblan 8/7/2012 8:52:05 AM(UTC)
Freezer Not Defrosting, ICING UP Model ED2FHEXSB02 (Refrigerator & Freezer Repair)
by Microman66 7/6/2012 8:10:36 PM(UTC)
KitchenAid bottom freezer not defrosting (Refrigerator & Freezer Repair)
by Telicoman 6/23/2012 8:55:03 AM(UTC)
by rebel53 4/15/2012 9:38:44 AM(UTC)
by peytond 2/22/2012 6:57:13 PM(UTC)
Whirlpool top freezer not defrosting (Refrigerator & Freezer Repair)
by frankla10 1/2/2012 5:11:32 PM(UTC)
Admiral refrigerator/top freezer not defrosting, and refrigerator getting warm (Refrigerator & Freezer Repair)
by 808BigShorty 1/7/2011 11:20:27 AM(UTC)
Freezer not Defrosting/Frig Side wWarm (Refrigerator & Freezer Repair)
by cajungirl 12/19/2010 9:18:06 PM(UTC)
Freezer not Defrosting (Refrigerator & Freezer Repair)
by Sam357 11/2/2010 1:53:27 PM(UTC)
