randd
#1 Posted : Thursday, September 19, 2013 2:22:14 PM(UTC)
randd
I have a fault code lE. The water pump is working and filling up both float bowls and then it I get the fault after they get full. The bottom of the dwshr fills up and that's it. I've checked the fill lines they are all good. The screen in the fill pump is clean.
Continuity is 1715 mil ohms on the filler pump. It also drains very well when I start a new wash cycle. It seems like it's on a timer for the water to fill up the float bowls. The micro switch on the fill side? is already made up and it continues to run.
High-pitched noise with LG dishwasher (Dishwasher Repair)
by Guest 5/17/2024 5:13:53 AM(UTC)
LG dishwasher bE Bubble Error (Dishwasher Repair)
by Guest 2/13/2024 10:58:29 AM(UTC)
LG dishwasher loud clicking noise after cycle completes (Dishwasher Repair)
by Guest 10/29/2023 6:43:16 AM(UTC)
LG Dishwasher will wash but won't dry (Dishwasher Repair)
by chrisguy 8/14/2023 2:12:31 PM(UTC)
LG Dishwasher Vents too much into door (Dishwasher Repair)
by 1of10inMD 5/1/2023 9:34:04 AM(UTC)
LG Dishwasher not cleaning dishes (Dishwasher Repair)
by diyrepairdishwasher 9/30/2022 5:50:39 AM(UTC)
LG dishwasher racks (Dishwasher Repair)
by Guest 8/16/2022 3:20:01 PM(UTC)
Error Codes on lg dishwasher LDF5545st (Dishwasher Repair)
by Guest 7/25/2022 10:57:38 AM(UTC)
LG Dishwasher LDS4821ST Drain issue (Dishwasher Repair)
by Guest 6/27/2022 12:40:11 PM(UTC)
Lg dishwasher whistling (Dishwasher Repair)
by Help89 2/1/2022 3:21:08 AM(UTC)
LG Dishwasher Leaking When First Turned On (Dishwasher Repair)
by artriumph 4/22/2021 1:13:56 PM(UTC)
LG Dishwasher - LDF7932ST (Dishwasher Repair)
by Raptor_57 2/6/2021 5:28:18 AM(UTC)
LG Dishwasher Srainless Discoloration/Rainbow (Dishwasher Repair)
by Thejdpuller 1/31/2021 6:17:49 PM(UTC)
cleaning LG dishwasher filter part ADQ32598202 (Dishwasher Repair)
by phillman5 9/4/2019 12:08:33 AM(UTC)
LG dishwasher shutting down after I select wash cycle (Dishwasher Repair)
by Jon Lamoureux 11/10/2018 10:42:42 AM(UTC)
