AppliancePartsPros.com
Appliance Repair Help
Dishwasher Repair
LG dishwasher loud clicking noise after cycle completes
Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
My LG dishwasher (model # LDTS5552D) is making a loud clicking noise after the cycle has completed when the dishwasher has the 'END' message on the display screen until I open the door. Once the door is opened the clicking noise stops even after the door is closed until the cycle runs, then it happens again every time the cycle has completed. I have audio of what it sounds like if there is a way I can attach it for you to hear
It appears that the loud clicking noise in your LG dishwasher (model # LDTS5552D) is likely associated with the completion of the cycle and persists until the door is opened. The issue may be related to the door latch mechanism or a component involved in the cycle completion process.
To troubleshoot, check for any visible obstructions around the door latch and ensure that it is functioning properly. Additionally, inspect the dishwasher's interior for loose items that might be causing the noise. If the problem persists, considering attaching the audio file could provide more insight into the specific sound, aiding in a more accurate diagnosis.
Dishwasher Repair
