I have a fault code lE. The water pump is working and filling up both float bowls and then it I get the fault after they get full. The bottom of the dwshr fills up and that's it. I've checked the fill lines they are all good. The screen in the fill pump is clean. Continuity is 1715 mil ohms on the filler pump. It also drains very well when I start a new wash cycle. It seems like it's on a timer for the water to fill up the float bowls. The micro switch on the fill side? is already made up and it continues to run.
