JimWilson
#1 Posted : 11 years ago
JimWilson
Looking for some schematic's for the main control pcb. The compressor is overheating because the fan is not turning on. It intermittent tho it works sometimes. I have replaced the fan thinking it was the fan but its not. If I catch it in time (freezer temp getting warm) and put a basic floor an blowing air on the compressor the temp will recover. I'm pretty sure I have a bad relay on the main control pcb AP4411082 that turns on and off the fan and I would like to pull the pcb and replace the relay (much cheaper repair) but I'm unsure what relay it is.
Any help would be appreciated.
Thank
Jim
#2 Posted : 11 years ago
Schematics of electronic boards are not available. Also, relays are very reliable, almost every time, the board electronics are bad.
JimWilson
#3 Posted : 11 years ago
JimWilson
I would agree but with this being an intermittent problem and the fact that I taped them with a screw driver and the fan started working its looking to me like a stuck relay. I should be able to determine the relay for the fan with a volt meter. I can buy a relay for 3 bucks I think it's worth trying before spending 2 hundred that's all.
#4 Posted : 11 years ago
Look on the back of the pc board for a bad solder connection, your most probable problem.
JimWilson
#5 Posted : 11 years ago
JimWilson
I can't get it to fail now. Pulled the control pcb and checked it for bad solder joints but found nothing wrong. Re-installed the pcb and the freezer has been at 0 deg for almost 2 days now. The compressor is running a little hot guessing because I have the back cover off and this does for force the air flow correctly.
I don't know what I should do, it's only going to happen again.
#6 Posted : 11 years ago
Get non-residue contact cleaner at Wall Mart and spay all connectors while removing and connecting.
2004 Kitchenaid side by side ctrl. board beeping (Refrigerator & Freezer Repair)
by morty343 11 years ago
KItchenaid side by side (Refrigerator & Freezer Repair)
by bmcclu01@earthlink.net 11 years ago
Fridge too cool - KitchenAid Side by Side (Refrigerator & Freezer Repair)
by OlaS 12 years ago
KitchenAid Side by Side Fan Runs Continuously (Refrigerator & Freezer Repair)
by clivedaw 12 years ago
KitchenAid side by side ref rig ice maker not working (Refrigerator & Freezer Repair)
by patjordan 12 years ago
Kitchenaid side by side light inside of freezer stopped working (Refrigerator & Freezer Repair)
by cajunyota 12 years ago
Kitchenaid side by side fridge frame is very hot (Refrigerator & Freezer Repair)
by bgbuss 13 years ago
KitchenAid side by side freezer refrigerator (Refrigerator & Freezer Repair)
by mnviking1968 14 years ago
Freezer KitchenAid Side by Side (Refrigerator & Freezer Repair)
by Cacti12u 14 years ago
Kitchenaid Side by Side Freezer not getting cold (Refrigerator & Freezer Repair)
by brent_floyd@yahoo.com 15 years ago
Kitchenaid side by side ice maker stopped working (Refrigerator & Freezer Repair)
by aloubo 15 years ago
Overflowing Drip Pan, KitchenAid Side by Side (Refrigerator & Freezer Repair)
by advocateone 15 years ago
KitchenAid Side by Side Fan runs 24hours (Refrigerator & Freezer Repair)
by nazmin 15 years ago
water filter leaking on Kitchenaid side by side (Refrigerator & Freezer Repair)
by DavidDouglas 15 years ago
Kitchenaid Side By Side Making Noise (Refrigerator & Freezer Repair)
by boolabonga 16 years ago
