JimWilson
#1 Posted : Saturday, August 31, 2013 12:39:21 PM(UTC)
JimWilson
Looking for some schematic's for the main control pcb. The compressor is overheating because the fan is not turning on. It intermittent tho it works sometimes. I have replaced the fan thinking it was the fan but its not. If I catch it in time (freezer temp getting warm) and put a basic floor an blowing air on the compressor the temp will recover. I'm pretty sure I have a bad relay on the main control pcb AP4411082 that turns on and off the fan and I would like to pull the pcb and replace the relay (much cheaper repair) but I'm unsure what relay it is.
Any help would be appreciated.
Thank
Jim
#2 Posted : Sunday, September 1, 2013 3:07:32 AM(UTC)
Schematics of electronic boards are not available. Also, relays are very reliable, almost every time, the board electronics are bad.
JimWilson
#3 Posted : Sunday, September 1, 2013 3:30:19 AM(UTC)
JimWilson
I would agree but with this being an intermittent problem and the fact that I taped them with a screw driver and the fan started working its looking to me like a stuck relay. I should be able to determine the relay for the fan with a volt meter. I can buy a relay for 3 bucks I think it's worth trying before spending 2 hundred that's all.
#4 Posted : Sunday, September 1, 2013 10:14:50 AM(UTC)
Look on the back of the pc board for a bad solder connection, your most probable problem.
JimWilson
#5 Posted : Sunday, September 1, 2013 6:39:59 PM(UTC)
JimWilson
I can't get it to fail now. Pulled the control pcb and checked it for bad solder joints but found nothing wrong. Re-installed the pcb and the freezer has been at 0 deg for almost 2 days now. The compressor is running a little hot guessing because I have the back cover off and this does for force the air flow correctly.
I don't know what I should do, it's only going to happen again.
#6 Posted : Monday, September 2, 2013 1:19:05 AM(UTC)
Get non-residue contact cleaner at Wall Mart and spay all connectors while removing and connecting.
2004 Kitchenaid side by side ctrl. board beeping (Refrigerator & Freezer Repair)
by morty343 7/24/2014 3:20:47 PM(UTC)
KItchenaid side by side (Refrigerator & Freezer Repair)
by bmcclu01@earthlink.net 5/7/2014 3:03:10 AM(UTC)
Fridge too cool - KitchenAid Side by Side (Refrigerator & Freezer Repair)
by OlaS 4/16/2013 3:52:36 PM(UTC)
KitchenAid Side by Side Fan Runs Continuously (Refrigerator & Freezer Repair)
by clivedaw 2/9/2013 10:37:05 PM(UTC)
KitchenAid side by side ref rig ice maker not working (Refrigerator & Freezer Repair)
by patjordan 1/4/2013 2:07:35 PM(UTC)
Kitchenaid side by side light inside of freezer stopped working (Refrigerator & Freezer Repair)
by cajunyota 9/6/2012 7:46:33 PM(UTC)
Kitchenaid side by side fridge frame is very hot (Refrigerator & Freezer Repair)
by bgbuss 7/22/2012 6:34:47 PM(UTC)
KitchenAid side by side freezer refrigerator (Refrigerator & Freezer Repair)
by mnviking1968 3/2/2011 2:38:50 PM(UTC)
Freezer KitchenAid Side by Side (Refrigerator & Freezer Repair)
by Cacti12u 9/20/2010 4:26:13 PM(UTC)
Kitchenaid Side by Side Freezer not getting cold (Refrigerator & Freezer Repair)
by brent_floyd@yahoo.com 7/11/2010 10:00:25 AM(UTC)
Kitchenaid side by side ice maker stopped working (Refrigerator & Freezer Repair)
by aloubo 2/19/2010 3:52:41 AM(UTC)
Overflowing Drip Pan, KitchenAid Side by Side (Refrigerator & Freezer Repair)
by advocateone 12/7/2009 11:55:41 AM(UTC)
KitchenAid Side by Side Fan runs 24hours (Refrigerator & Freezer Repair)
by nazmin 10/27/2009 12:27:42 PM(UTC)
water filter leaking on Kitchenaid side by side (Refrigerator & Freezer Repair)
by DavidDouglas 10/8/2009 7:22:40 AM(UTC)
Kitchenaid Side By Side Making Noise (Refrigerator & Freezer Repair)
by boolabonga 7/9/2009 5:57:17 PM(UTC)
