LMK
#1 Posted : 12 years ago
LMK
I have a 1998 6 burner Thermador Cooktop on which one burner stopped working. Using Gene's suggestion I was able to remove the burner in order to replace the ignition plug by using two crescent wrenches, however after removing the clip and spring I was unable to remove plug. Since the new plug I received from Bosch clearly was much larger than I needed I decided to switch the burner assembly with one of the other five burners that were working properly. To my surprise the old plug had no trouble igniting the other burner but the plug from that burner would not light the first and I lit by match the igniter plugs continue to fire on other burners .
1. Should I replace igniter control?
2. How do i remove ignition plug from burner.
3. Is a proper igniter plug available
LMK
#2 Posted : 12 years ago
LMK
Thermador Pro Cooktop Ignition replacement
THERMADOR COOKTOP PCG366G (Oven Repair (including Ranges and Cooktops))
by pjl2000 2 years ago
Thermador cooktop, no spark or gas for XLO burners (Oven Repair (including Ranges and Cooktops))
by Guest 3 years ago
Thermador cooktop burner keeps clicking after igniting (Oven Repair (including Ranges and Cooktops))
by dcdwyer 4 years ago
HELP: Remove Thermador cooktop (SGVC36G01) top access (Oven Repair (including Ranges and Cooktops))
by jrbarlow22 4 years ago
SGSX365FS/03 Thermador Cooktop (Oven Repair (including Ranges and Cooktops))
by mike3000 4 years ago
Thermador Cooktop Ignition Problems (Oven Repair (including Ranges and Cooktops))
by HotPepperFan 9 years ago
Burner problem with Thermador Cooktop (Oven Repair (including Ranges and Cooktops))
by philw007 10 years ago
Thermador Cooktop Griddle Doesn't Heat Properly (Oven Repair (including Ranges and Cooktops))
by HotPepperFan 12 years ago
thermador cooktop problems (Oven Repair (including Ranges and Cooktops))
by billg87 12 years ago
Remove front panel of Thermador Cooktop (Oven Repair (including Ranges and Cooktops))
by hloos 12 years ago
Thermador Cooktop Spark Module (Oven Repair (including Ranges and Cooktops))
by randydodd 12 years ago
thermador cooktop halogen burner partially working (Oven Repair (including Ranges and Cooktops))
by judith w 13 years ago
Weak Spark on Thermador Cooktop (Oven Repair (including Ranges and Cooktops))
by cwilliamrose 13 years ago
One igniter stopped working on my Thermador cooktop (Oven Repair (including Ranges and Cooktops))
by ingas 13 years ago
Thermador Cooktop XLO Burners (Oven Repair (including Ranges and Cooktops))
by gimidlin 13 years ago
