After pushing the Bake or Pre Heat button and setting the temperature, the oven does not ignite and the display turns off after a few seconds.:mad::mad::mad:
Most likely the problem caused by the Electronic Oven Control (clock). - The part number for the EOC with the almond overlay is AP2150429 Here are the break down diagrams for the Frigidaire range Model FGF374CCTD. Gene.
