rska
#1 Posted : Thursday, June 27, 2013 2:42:26 PM(UTC)
rska
I have a built-in GE Monogram refrigerator (model #ZIC360N) with a bottom freezer with an ice maker. The refrigerator keeps a temperature between 36̊ and 39̊ but the freezer remains in the high 20s. The coils in the back of the freezer have frosted over. I defrosted it manually last week and got the freezer temp down to 3̊, but that no longer works. I defrosted it again this morning at 3:30 AM, replaced the contents at 4:30 AM and without opening the freezer again it has only gotten to 27̊ fifteen hours later. The motor constantly runs and makes a little more noise than usual.
In June of 2012 the dryer ((part #WR86X96) and an access valve (part #WJ56X61) were replaced by a GE service technician; the actual problem was a slow freon leak from a tube below the refrigerator which was finally fixed in September. In August of 2009 the thermostat (part #WR50X1003)) and the sensor temp ff (part #WR55X10025) were replaced by a GE tech after another initial misdiagnosis.
I’d rather not rely on GE service. I’m handy with tools and can follow instructions. Is there a part I can replace myself that will fix this?
#2 Posted : Friday, June 28, 2013 2:25:11 AM(UTC)
Seems like the leak was not fixed. Check the compressor, if it is warm and vibrating and the condenser not hot, you have a refrigerant leak and probably a damaged compressor. Pressure gauges would confirm.
GE DFE29JMDEES warm freezer (Refrigerator & Freezer Repair)
by wallyh3128 5/24/2023 4:52:35 AM(UTC)
Frigidaire side by side - warm freezer cold fridge - help please (Refrigerator & Freezer Repair)
by Doug427 1/23/2023 4:36:18 PM(UTC)
by paulmars 3/31/2018 10:25:06 AM(UTC)
Whirlpool Gold Conquest: compressor constantly running & warm freezer (Refrigerator & Freezer Repair)
Belarus dawydiuk 12/4/2016 6:11:31 AM(UTC)
Kenmore Side By Side Fridge Warm Freezer Good (Refrigerator & Freezer Repair)
by craig72 7/15/2015 9:23:52 AM(UTC)
Amana warm freezer and refer could jazz board be the issue if all tests good (Refrigerator & Freezer Repair)
by jimholstrom@yahoo.com 10/22/2014 12:58:03 PM(UTC)
warm Freezer, frozen yogurt in main section (Refrigerator & Freezer Repair)
by ABQGE 12/17/2013 7:52:41 PM(UTC)
Fridge warm freezer cold - First repair done (Refrigerator & Freezer Repair)
by phatdawg 12/5/2013 7:54:14 AM(UTC)
Refrigerator warm Freezer ok (Refrigerator & Freezer Repair)
by larbear 8/24/2013 7:24:21 PM(UTC)
Built in Kitchenaid warm freezer occasionally (Refrigerator & Freezer Repair)
by jphemi 3/20/2013 6:46:18 PM(UTC)
Fridge is warm freezer cold (Refrigerator & Freezer Repair)
by Suzanne brugger 8/28/2012 2:39:42 PM(UTC)
regfrigerator to warm freezer ok (Refrigerator & Freezer Repair)
by hfox1 8/15/2012 9:08:52 AM(UTC)
refrigerator warm freezer ok (Refrigerator & Freezer Repair)
by Am obil 11/22/2011 7:40:42 PM(UTC)
Compressor short runs, warm freezer fridge (Refrigerator & Freezer Repair)
by Drgnflys 10/2/2011 6:42:39 PM(UTC)
Refrigerator too warm Freezer fine (Refrigerator & Freezer Repair)
by kinijean 7/13/2011 1:17:18 PM(UTC)
