2 Pages12>
Eigenbrod
#1 Posted : Monday, June 10, 2013 4:53:56 AM(UTC)
Eigenbrod
My washing machine does everything it is supposed to do. It fills correctly, drains and all that but will not spin. It makes the sounds like it is going to spin but does not. There are not burning smells or anything. What could this possibly be.
fairbank56
#2 Posted : Monday, June 10, 2013 5:52:42 AM(UTC)
fairbank56
Groups: Expert
Does it agitate?
Eric
Eigenbrod
#3 Posted : Monday, June 10, 2013 6:55:48 AM(UTC)
Eigenbrod
It does not. Makes all the noise that it is going to though.
fairbank56
#4 Posted : Monday, June 10, 2013 7:06:23 AM(UTC)
fairbank56
Groups: Expert
Remove the front panel of the washer and check for a broken belt at bottom of washer between motor pulley and main drive pulley. Pulleys and belt should rotate freely with washer off. If ok, check the blinking LED on top right side of motor/inverter board for error codes. Normal is LED blinking on/off at about 1 second interval. An error is indicated by faster flashing and then off within a 6 second interval. The number of flashes in the 6 second period is the error number.
Eric
Eigenbrod
#5 Posted : Monday, June 10, 2013 8:25:55 AM(UTC)
Eigenbrod
Eric
Looks like the belt is ok, kind of confused though since this dryer if very basic and doesn't have a screen that build blink.
Eigenbrod
#6 Posted : Monday, June 10, 2013 8:51:44 AM(UTC)
Eigenbrod
Also makes a ticking noise like it wants to spin.
fairbank56
#7 Posted : Monday, June 10, 2013 9:03:48 AM(UTC)
fairbank56
Groups: Expert
Dryer? I thought this was a washer? Anyway, the LED is a very small indicating "lamp" on the top right side of the inverter board. May be easier to view from right side of board.
Eric
UserPostedImage
Eigenbrod
#8 Posted : Monday, June 10, 2013 9:24:37 AM(UTC)
Eigenbrod
Eric
UserPostedImage
Oh sorry it is the washer, not sure why I said dryer.
Eigenbrod
#9 Posted : Monday, June 10, 2013 12:03:07 PM(UTC)
Eigenbrod
Eric
10 blinks it looks like, had Mom check.
Eigenbrod
#10 Posted : Monday, June 10, 2013 12:17:03 PM(UTC)
Eigenbrod
SORRY BUT IT IS 4 BLINKS.
Whirlpool washing machine not spinning properly (Washer Repair)
by Guest 6/9/2021 9:12:59 PM(UTC)
Kenmore washing machine not spinning without help (Washer Repair)
by narcsisuss 7/6/2015 5:54:17 AM(UTC)
GE Washing Machine not spinning consistently (Washer Repair)
by Rjr19146 11/5/2012 6:15:45 AM(UTC)
WaShing Machine not spinning (Washer Repair)
by DennisBarrineau 9/1/2012 10:43:36 AM(UTC)
Washing machine not spinning (Washer Repair)
by jjlittle.64 8/27/2012 10:29:37 PM(UTC)
washing machine not spinning (Washer Repair)
by tessjones 6/12/2010 1:19:26 PM(UTC)
by jennyl11 11/20/2009 11:38:31 PM(UTC)
Frigidaire Top Loading Washing Machine not Spinning (Washer Repair)
by truett 6/27/2009 10:12:24 AM(UTC)
Kenmore washing machine not spinning (Washer Repair)
by Jim Bender 5/6/2009 7:48:20 AM(UTC)
2 Pages12>
