kricca
#1 Posted : Tuesday, November 13, 2012 5:32:02 PM(UTC)
kricca
I have a Maytag washer model LA25CS It fills up with water, when the tub is full instead of agitating the drum spins with the water in it. I put my foot against the transmission and it did not agitate. If I advance the timer the water drains out and the washer spins normal. When the machine is off I can take my hand and turn the agitator and drum with no resistance at all. I checked the belts and they are fine. Not sure if I have a brake or transmission problem.
#2 Posted : Wednesday, November 14, 2012 3:06:14 PM(UTC)
Sounds like the transmission is the culprit. If you need the correct part number, post the serial number of the washer.
kricca
#3 Posted : Thursday, November 15, 2012 3:22:36 AM(UTC)
kricca
Thanks Gene
The serial number is 202939 XJ
#4 Posted : Thursday, November 15, 2012 11:59:52 AM(UTC)
The transmission assembly Part number: 6-2097750
kricca
#5 Posted : Friday, November 16, 2012 4:24:11 AM(UTC)
kricca
Thank you Gene. I just ordered it
#6 Posted : Friday, November 16, 2012 2:22:19 PM(UTC)
kricca
#7 Posted : Saturday, December 8, 2012 6:13:57 PM(UTC)
kricca
I was finally able to remove the transmission from the machine and went to install the Trans Dee. It looks like I have the deep tub because the transmission is shorter than the one I removed, do you have a part number for a deep tub transmission for this model? Thank you
#8 Posted : Tuesday, December 11, 2012 12:12:54 PM(UTC)
I double checked the part number I posted earlier and this is the part number for deep tub transmission. The other part number for this model number is 6-2097790.
Another question I did not ask you earlier (sorry about it) is: had you messed with the drive lug that goes on the bottom of the lower shaft? If it's not in the right place it will prohibit the pulley from coming back down and allowing the brake to re-engage
Washer not agitating, spinning or draining. (Washer Repair)
by Guest 12/28/2023 2:09:09 PM(UTC)
wASHER NOT AGITATING BUT SPINS AND DRAINS (Washer Repair)
by slider13 3/13/2017 3:59:10 AM(UTC)
washer not agitating (Washer Repair)
by Jbeardsley03 2/14/2017 8:19:53 AM(UTC)
washer not agitating except in delicate (Washer Repair)
by Wiconi 12/21/2015 9:11:18 AM(UTC)
GE Washer Not Agitating or Spinning (Washer Repair)
by Gator84 8/17/2015 4:34:56 PM(UTC)
Washer not agitating during wash cycle. (Washer Repair)
by Campisifamily 1/9/2015 6:02:57 PM(UTC)
GE Front Load Washer Not Agitating or Spinning (Washer Repair)
by mghump 12/16/2013 6:13:15 AM(UTC)
by KerriH 7/19/2013 9:06:57 AM(UTC)
GE washer not agitating (Washer Repair)
by rfm1 5/21/2013 3:54:45 AM(UTC)
Maytag washer not agitating in the wash or rinse cycle (Washer Repair)
by kstev 4/7/2013 11:29:23 AM(UTC)
GE Washer Not Agitating (Washer Repair)
by eosada 2/17/2013 6:10:32 AM(UTC)
Kenmore washer not agitating (Washer Repair)
by VentureRider 11/15/2012 1:02:26 PM(UTC)
Washer not agitating or spinning help please (Washer Repair)
by oxtart 9/10/2012 6:54:23 AM(UTC)
Kenmore Washer Not Agitating (Washer Repair)
by ditosp 8/8/2012 4:10:36 PM(UTC)
GE washer not agitating properly (Washer Repair)
by aav 6/23/2012 8:30:14 AM(UTC)
