kricca
#1 Posted : 12 years ago
kricca
I have a Maytag washer model LA25CS It fills up with water, when the tub is full instead of agitating the drum spins with the water in it. I put my foot against the transmission and it did not agitate. If I advance the timer the water drains out and the washer spins normal. When the machine is off I can take my hand and turn the agitator and drum with no resistance at all. I checked the belts and they are fine. Not sure if I have a brake or transmission problem.
#2 Posted : 12 years ago
Sounds like the transmission is the culprit. If you need the correct part number, post the serial number of the washer.
kricca
#3 Posted : 12 years ago
kricca
Thanks Gene
The serial number is 202939 XJ
#4 Posted : 12 years ago
The transmission assembly Part number: 6-2097750
kricca
#5 Posted : 12 years ago
kricca
Thank you Gene. I just ordered it
#6 Posted : 12 years ago
kricca
#7 Posted : 12 years ago
kricca
I was finally able to remove the transmission from the machine and went to install the Trans Dee. It looks like I have the deep tub because the transmission is shorter than the one I removed, do you have a part number for a deep tub transmission for this model? Thank you
#8 Posted : 12 years ago
I double checked the part number I posted earlier and this is the part number for deep tub transmission. The other part number for this model number is 6-2097790.
Another question I did not ask you earlier (sorry about it) is: had you messed with the drive lug that goes on the bottom of the lower shaft? If it's not in the right place it will prohibit the pulley from coming back down and allowing the brake to re-engage
Washer not agitating, spinning or draining. (Washer Repair)
by Guest about a year ago
wASHER NOT AGITATING BUT SPINS AND DRAINS (Washer Repair)
by slider13 8 years ago
washer not agitating (Washer Repair)
by Jbeardsley03 8 years ago
washer not agitating except in delicate (Washer Repair)
by Wiconi 9 years ago
GE Washer Not Agitating or Spinning (Washer Repair)
by Gator84 10 years ago
Washer not agitating during wash cycle. (Washer Repair)
by Campisifamily 10 years ago
GE Front Load Washer Not Agitating or Spinning (Washer Repair)
by mghump 11 years ago
by KerriH 12 years ago
GE washer not agitating (Washer Repair)
by rfm1 12 years ago
Maytag washer not agitating in the wash or rinse cycle (Washer Repair)
by kstev 12 years ago
GE Washer Not Agitating (Washer Repair)
by eosada 12 years ago
Kenmore washer not agitating (Washer Repair)
by VentureRider 12 years ago
Washer not agitating or spinning help please (Washer Repair)
by oxtart 12 years ago
Kenmore Washer Not Agitating (Washer Repair)
by ditosp 13 years ago
GE washer not agitating properly (Washer Repair)
by aav 13 years ago
