jledereich
#1 Posted : Tuesday, September 22, 2009 9:51:35 AM(UTC)
jledereich
Bottom oven temp sensor broken. Oven burns continuessly.
Not sure of the part number to replace the sensor. Is Whirlpool part 8053344? Is it the same as for the top oven?
I've already replaced the top oven sensor but has its own problems, more complex since top oven is computer controled.
#2 Posted : Wednesday, September 23, 2009 9:51:39 AM(UTC)
There is no temperature sensor in the lower oven. The temperature in this oven controls by the oven thermostat (#19 on the diagram).
- The lower oven thermostat Part number: AP3031566
jledereich
#3 Posted : Wednesday, September 23, 2009 10:00:24 AM(UTC)
jledereich
Thank you for your response. So then I may be wrong in defining the part that I think I need. The bottom oven has some kind of a hard cable attached to something like a metal like stick, protrudes into the oven from a hole in the ceiling of the bottom oven (towards the left side) and arrears to be held in place by some clip. I can not find this part in the diagrams. This part has bent and broken off. Now the oven just burns. That's why I thought it was a temperature sensor.
#4 Posted : Saturday, September 26, 2009 3:10:05 PM(UTC)
Sorry for the delay.
The part you described is the oven thermostat temperature sensing bulb which is a part of the oven thermostat. So the correction of this problem is to replace the oven thermostat.
whirlpool double wall oven BROIL on BAKE (Oven Repair (including Ranges and Cooktops))
by Guest 6/4/2023 8:04:00 PM(UTC)
Whirlpool double wall oven lower not heating (Oven Repair (including Ranges and Cooktops))
by mid 5/23/2022 12:46:49 PM(UTC)
Whirlpool Double Wall Oven Dead after Self Clean - Door Locked (Oven Repair (including Ranges and Cooktops))
by cmartin27 1/19/2018 1:24:46 PM(UTC)
Whirlpool double wall oven (Oven Repair (including Ranges and Cooktops))
by PotRoastMan 1/9/2015 6:04:08 AM(UTC)
by dragonflies64 9/23/2014 7:07:41 PM(UTC)
Whirlpool double wall oven (electric) upper oven not working (Oven Repair (including Ranges and Cooktops))
by JayTeeC 3/11/2014 4:54:07 PM(UTC)
Whirlpool Double Wall Oven (Oven Repair (including Ranges and Cooktops))
by abinosa 6/19/2013 10:34:26 AM(UTC)
Whirlpool Double Wall Oven Fan (Oven Repair (including Ranges and Cooktops))
by bernardv 3/10/2012 9:57:23 AM(UTC)
by myoven 11/22/2011 6:38:55 AM(UTC)
Removing trim and control panel from Whirlpool double wall oven (Oven Repair (including Ranges and Cooktops))
by Lifterfe 4/23/2011 4:10:10 PM(UTC)
Whirlpool double wall oven E6 F2 code, then blank display (Oven Repair (including Ranges and Cooktops))
by jvr888 10/31/2010 7:20:02 PM(UTC)
Whirlpool Double Wall Oven Won't Heat... (Oven Repair (including Ranges and Cooktops))
by DaveinMD 12/1/2009 6:28:08 AM(UTC)
Whirlpool Double Wall Oven D.O.A (Oven Repair (including Ranges and Cooktops))
by JaredB 12/8/2008 6:24:40 PM(UTC)
Whirlpool Double wall oven DEAD after self cleaning cycle rbd306pd (Oven Repair (including Ranges and Cooktops))
by sillyshopper 2/9/2008 8:02:27 AM(UTC)
Whirlpool Double Wall Oven - Top Oven Not Working (Oven Repair (including Ranges and Cooktops))
by bigguy 11/15/2007 7:18:45 AM(UTC)
