DaveinMD
#1 Posted : Tuesday, December 1, 2009 6:28:08 AM(UTC)
DaveinMD
Hello,
Just bought a new (to me) house that came with a Whirlpool Accubake double wall oven. First thing we did was run the self clean which caused the oven to overheat. I came straight here and started reading about what a common problem this is. I replaced the thermal fuse on the control panel and that got the display working. However, neither the top nor bottom oven will heat up. The fans run and the lights all work, but the ovens don't get hot.
The top oven display is on the left (I think) and we can set it to a desired temp and the fans run and the preheat timer counts down, but the temp never gets warm. We can't even get the temp to display on the right (bottom oven I assume).
My questions:
- Are there thermal fuses (part 37) for each oven? I thought in reading others' posts about this topic that there was only one.
- Is something else going on that I can't even set the temp on the lower oven? Doesn't seem like a thermal fuse replacement would cure that.
Thanks much for your help. Great forum and great website - I've fixed both a KitchenAid d/w and stove with parts/help from this site.
Dave
#2 Posted : Wednesday, December 2, 2009 6:24:36 AM(UTC)
Replacement parts for WHIRLPOOL RBD306PDQ6 | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/d...0Sheet%20-%204452022.pdfhttp://shared.whirlpoolc...0Guide%20-%204450568.pdf
And a service manual
https://secured.whirlpoo...524e76/$FILE/8178007.pdf
Here also is the operators manual as it sounds like you do not have it
Since I do not see a fuse that will kill power to both ovens my gut says that you have lost the 240 volts. Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without tripping the breaker.
Better yet measure it at the oven with a meter.
My questions:
Yes if the wiring diagram is correct but depends on the oven.
Yes this is worry some. As a fuse should not do this. Also if the sensor was gone I think you would get an error code. If the blower did not come on during self clean, it could be that the heat took out the board.
DaveinMD
#3 Posted : Wednesday, December 2, 2009 6:45:23 AM(UTC)
DaveinMD
Den Man - Thanks so much. I didn't have any sort of manuals for this oven as you suspected. Your trick worked - I flicked the breaker very slowly and now have power (in the display) and heat in the lower oven. I'll try a thermal fuse for the upper oven and will report back.
Thanks for taking the time to respond with so much info/links.
Dave
