rlshepard
#1 Posted : Monday, August 6, 2012 5:22:57 PM(UTC)
rlshepard
We have water left in the tub at the end of a cycle, I've pulled the drain hose from the sink and watched the water run into a bucket, but it just doesnt empty all the way...
I pulled the sump apart and cleaned it out, man was it yucky in there... but still the same result.... Any ideas? It's almost like the pump just isn't running long enough? is there something else I should clean?
#2 Posted : Wednesday, August 8, 2012 1:54:36 AM(UTC)
Replacement parts for General Electric GHD5025F01BB Dishwasher | AppliancePartsPros.com
I would check the piston and nut (Item 564 in Section 1). It is behind the screen filter at the back of the tub. It unscrews.
If it does not seal properly then during drain some water leaks back into the tub instead of going out the drain.
Will not drain on spin cycle (Washer Repair)
by Guest 8/7/2022 8:04:16 AM(UTC)
Whirlpool will not drain or cycle. No Obstructions. What next?? (Dishwasher Repair)
by RyGuy73 3/2/2020 6:29:56 PM(UTC)
Kenmore Model 665.13269K110 will not drain (Dishwasher Repair)
by LoserKorn 4/14/2019 1:21:36 PM(UTC)
Ge dishwasher will not drain (Dishwasher Repair)
by Handyman924 2/24/2017 8:05:27 PM(UTC)
Samsung Front Loader will not drain (Washer Repair)
by orangecrush 4/18/2016 6:32:48 PM(UTC)
maytag washer will not drain water (Washer Repair)
by mathy10544 12/13/2015 8:54:09 PM(UTC)
GE front load washer will not drain (Washer Repair)
by Sandmann01 6/22/2015 1:24:04 AM(UTC)
Washer will not drain (Washer Repair)
by Artnlp 5/3/2015 7:34:59 AM(UTC)
Washer will not drain in Normal cycle (Washer Repair)
by rober luck 4/20/2015 9:10:47 AM(UTC)
Whirlpool stops after wash cycle will not drain or spin (Washer Repair)
by JF2015 1/4/2015 7:19:52 AM(UTC)
by charles140 10/10/2014 8:21:01 AM(UTC)
maytag will not drain (Washer Repair)
by john rodriguez 7/15/2014 8:28:54 PM(UTC)
Maytag atlantis will not drain or spin (Washer Repair)
by Militoni 7/12/2014 3:34:57 AM(UTC)
by hurler72 11/25/2013 10:59:35 AM(UTC)
Whirlpool QPII not bringing in water, also will not drain (Dishwasher Repair)
by hawkeye680 11/2/2013 9:13:43 AM(UTC)
