eckroo
#1 Posted : Thursday, September 17, 2009 1:03:21 PM(UTC)
eckroo
I have a top load washer that leaks because the drum is tilted at an angle. The water would hit the rim of the drum/tub and leak out from the back. I found a broken spring part# AP4459650 and had that replaced. I even had the suspension spring and suspension bracket removed. Yet the problem is still there. Can someone help me? Thanks.
sidfink43
#2 Posted : Friday, September 18, 2009 3:41:23 PM(UTC)
sidfink43
You have been a member since:: 3/29/2009(UTC)
See if this link will help you.
http://www.applianceaid.com/suspention.html
If you need more info please post your full model number so we are certain which type of machine we are working with.
eckroo
#3 Posted : Saturday, September 19, 2009 7:39:45 PM(UTC)
eckroo
The model# is LA5558xswo. Thanks.
sidfink43
#4 Posted : Sunday, September 20, 2009 5:19:09 AM(UTC)
sidfink43
Sounds like a problem with your suspension or pads.
Take a look at this site for some guidance
eckroo
#5 Posted : Wednesday, September 23, 2009 11:31:11 AM(UTC)
eckroo
Hey Sidfink43, I have already changed the suspension springs. So all 4 springs have already been replaced. However, the drum is still tilted towards the motor. I have no clue why. Does the drum need to be alined or something???
sidfink43
#6 Posted : Wednesday, September 23, 2009 11:36:18 AM(UTC)
sidfink43
The drum is not aligned on anything, and the whole apparatus floats on the suspension pads. Sounds like something out of whatck on your suspension, may have occurred when you replaced the springs but without being there I really cannot add much more to the conversation.
Maybe someone else can chime in here.
eckroo
#7 Posted : Wednesday, September 23, 2009 1:23:06 PM(UTC)
eckroo
Is the skate plate kit suppose to be 'loose'. Nothing seems to be attached to it.
Leaking Washer (Washer Repair)
by midget73 7/27/2014 3:27:00 PM(UTC)
by broonsparrow 11/30/2013 10:15:30 AM(UTC)
Leaking washer need advice (Washer Repair)
by GE Nightmare 10/5/2013 1:54:30 PM(UTC)
leaking washer (Washer Repair)
by ashkdaot 6/25/2013 6:23:18 PM(UTC)
by Jags 12/22/2012 8:37:52 AM(UTC)
by martha725 8/3/2012 2:11:37 PM(UTC)
leaking washer and won't drain (Dishwasher Repair)
by colt 11/6/2011 2:15:14 PM(UTC)
leaking washer (Oven Repair (including Ranges and Cooktops))
by cheery 11/5/2011 6:14:56 PM(UTC)
Leaking washer (Washer Repair)
by Crowell 9/6/2011 9:11:30 AM(UTC)
leaking washer during filling (Washer Repair)
by bonnetinsurance 8/10/2011 7:44:44 AM(UTC)
by 03svrider 6/9/2011 10:48:37 AM(UTC)
by rcarroll7703 6/1/2011 7:50:27 AM(UTC)
by donandlynn 5/7/2011 7:32:41 AM(UTC)
by Mrkis 1/30/2011 9:09:01 AM(UTC)
by Clueless101 12/27/2010 12:33:13 PM(UTC)
