Dryer runs but will not get hot. Could this be the heating Element? How can I be sure that it is the Heating Element?
Here are your parts Replacement parts for WHIRLPOOL LEC8858DQ1 | AppliancePartsPros.comHere is the wiring diagram http://www.servicematters.com/d...0Sheet%20-%203401725.pdfTry it in timed dry as this is the simplest mode. Yes it could be the heating element. Can usually be checked by re♦moving it and checking it visually. Also can be checked with a meter while in place. Here is a good site with additional help re: dis-assembly etc. http://www.applianceaid.com/dryers.htmlIf you do not own a meter, I would suggest you purchase a one. You can get a decent digital multimeter for under $20.00. You do not need fancy though it is nice if the leads are a couple feet long. If it saves ordering one unnecessary part it has paid for itself and you end up owning a useful tool. Most places will not let you return electrical parts so if you order it, you own it. A couple things to watch when measuring ohms and continuity 1. Always remove power from the machine otherwise you could blow your meter. 2. Always disconnect at least one side of any device you are checking. This eliminates the possibility of measuring an alternate/parallel circuit path. 3. When checking for closed contacts and continuity use the lowest scale (Usually 200 ohms). Then try higher scales. This scale is 0 to 200 ohms so if the device you are measuring is 300 ohms this scale would show an open circuit which it is not, you are just measuring outside the scale's dynamic range. There is a good STICKY at the start of this forum about it's use. |
THIS FORUM IS DEAD!!!!!!! |
