crmullins
#1 Posted : Monday, July 9, 2012 9:36:41 PM(UTC)
crmullins
Had a brown out and my Maytag dryer (MEDB200VQ0) apparently is the only victim. It won't start. Diagnostic tests reported "F01" followed by a "C0" and so I ordered a replacement control board (W10111621). Switched in the replacement board and it still won't start. Diagnostic tests now only report "C0" which as far as the internet is concerned is an unknown code. Anyone else know how to proceed?
#2 Posted : Tuesday, July 10, 2012 7:50:01 PM(UTC)
Did you check the thermal fuse (#41 at the diagram), the belt and the door switch?
- The thermal fuse Part number: 3390719
crmullins
#3 Posted : Wednesday, July 18, 2012 11:12:18 AM(UTC)
crmullins
Belt and door switch are good. No continuity on the thermal fuse, so time to replace. Checked the Thermistor (#51 on diagram) on the blower and it was in range. Should I also test the Thermal Cut-Off and Thrmst Fix (#47 and #48 on diagram) ?
Simon / APP Team
#4 Posted : Wednesday, July 18, 2012 11:56:24 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Yes you may and if needed - replace them.
Thank you.
Simon.
Guest (6)
Maytag dryer won't start (Dryer Repair)
by eagle243 11/15/2017 6:44:39 PM(UTC)
Maytag Dryer won't start when hot (Dryer Repair)
by MrFrisco 12/9/2012 5:58:05 PM(UTC)
by timmykang 6/23/2012 12:21:08 PM(UTC)
Maytag Dryer won't start (Dryer Repair)
by tmckeithan 11/30/2011 5:07:47 PM(UTC)
by cah14522 2/10/2011 2:43:44 PM(UTC)
by ssp123 2/11/2010 3:23:28 PM(UTC)
Maytag dryer won't start- thermostat question? (Dryer Repair)
by Underdog 1/30/2010 4:43:58 AM(UTC)
Maytag dryer WON'T START ! (Dryer Repair)
by souptafied 5/22/2009 4:25:25 PM(UTC)
Maytag dryer won't start....... (Dryer Repair)
by ShaNene 3/4/2009 8:40:55 AM(UTC)
Maytag dryer won't start Help!!!! (Dryer Repair)
by Dwatts 11/17/2007 9:54:55 AM(UTC)
