First can someone tell me how to find the model number, where it is located. Tried to see if it would say location on this site anywhere in a service manual but it doesn't. Also my problem is that the dryer just won't start up. I push the start button and nothing. Opened up the top of dryer and the little pockets provided along the back. Wires seem to all be connected and stable. A little dusty so I cleaned it up a little bit inside. From what I've read so far on this site is that the not starting issue can be a few things one of which being the Thermal fuses, I think I have found one of them, but I need to know how to check the fuse also what else this problem may be. I know nothing about dryers so the more clear and simple termed you are the better, thanks
Originally Posted by: ShaNene  First can someone tell me how to find the model number, where it is located. Tried to see if it would say location on this site anywhere in a service manual but it doesn't. Also my problem is that the dryer just won't start up. I push the start button and nothing. Opened up the top of dryer and the little pockets provided along the back. Wires seem to all be connected and stable. A little dusty so I cleaned it up a little bit inside. From what I've read so far on this site is that the not starting issue can be a few things one of which being the Thermal fuses, I think I have found one of them, but I need to know how to check the fuse also what else this problem may be. I know nothing about dryers so the more clear and simple termed you are the better, thanks how do we get to the thermal fuse and know if that is the problem
Was thanked: 10 time(s) in 10 post(s)
THIS FORUM IS DEAD!!!!!!! |
