Had a brown out and my Maytag dryer (MEDB200VQ0) apparently is the only victim. It won't start. Diagnostic tests reported "F01" followed by a "C0" and so I ordered a replacement control board (W10111621). Switched in the replacement board and it still won't start. Diagnostic tests now only report "C0" which as far as the internet is concerned is an unknown code. Anyone else know how to proceed?
Belt and door switch are good. No continuity on the thermal fuse, so time to replace. Checked the Thermistor (#51 on diagram) on the blower and it was in range. Should I also test the Thermal Cut-Off and Thrmst Fix (#47 and #48 on diagram) ?
Groups: APP Team
Hi.
Yes you may and if needed - replace them.
Thank you.
Simon.
