tomromeyn7
#1 Posted : Sunday, June 3, 2012 2:57:52 PM(UTC)
tomromeyn7
First time the Dryer is turned on, burner comes on and goes out (stays on for "normal" amount of time). When the burner tries to light again, ignitor glows and occasionally the burner lites. Approximately every 4 or 5 time, the burner lites. Replace the thermostat and thermal cut-off. Coils on burner deflective?
#2 Posted : Monday, June 4, 2012 1:16:09 PM(UTC)
Most likely the problem is a bad gas valve coils. This is very common problem with all gas dryers.
- The coil kit Part number: 279834
GE profile harmony gas dryer does not heat (Dryer Repair)
by wonder88 8/30/2015 2:22:05 PM(UTC)
dryer does not heat up as high as it use to (Dryer Repair)
by bubba1915 3/8/2014 5:49:40 PM(UTC)
Dryer does not heat anymore (Dryer Repair)
by yellowsir 2/28/2014 8:09:39 AM(UTC)
Dryer does not heat (gas) (Dryer Repair)
by SCOTT4 2/2/2013 7:47:15 AM(UTC)
Dryer does not heat, but runs, all parts seem to be good (Dryer Repair)
by discgolfdoug 10/14/2012 8:01:10 PM(UTC)
whirlpool duet electric dryer does not heat (Dryer Repair)
by alxholbrook 9/28/2012 6:21:38 AM(UTC)
Kenmore H3 Dryer does not heat (Dryer Repair)
by tim75 8/7/2012 10:12:46 AM(UTC)
Electric dryer does not heat. (Dryer Repair)
by Wtucker 4/19/2012 11:10:26 AM(UTC)
by thabersaat 2/27/2012 11:10:06 AM(UTC)
Kenmore Elite Dryer does not heat up (Dryer Repair)
by cjagadheshan 12/13/2011 5:11:32 PM(UTC)
by lingo622 9/22/2011 12:03:52 PM(UTC)
Whirlpool dryer does not heat on medium setting (Dryer Repair)
by redcagle 7/28/2011 10:55:43 AM(UTC)
by nwiccauto 6/16/2011 10:02:50 AM(UTC)
Whirlpool dryer does not heat (Dryer Repair)
by jkaffel 5/19/2011 2:34:34 PM(UTC)
by David schuler 4/26/2011 12:29:11 PM(UTC)
