redcagle
#1 Posted : Thursday, July 28, 2011 10:55:43 AM(UTC)
redcagle
Dryer works on high setting but not on medium heat setting. Have cleaned and checked vents for lint. Someone told me it is the timer which is $200, so might as well buy a new dryer. Help?
#2 Posted : Thursday, July 28, 2011 1:34:35 PM(UTC)
Locate the cycling thermostat on the blower housing. It has 4 prongs. Measure the resistance across the two small prongs. Normally it should be between 4500 Ohms to 9000 Ohms. If the reading is incorrect, replace the thermostat.
- The cycling thermostat Part number: AP2042618
Here are the breakdown diagrams and Replacement parts for General Electric DWSR483EB0WW Electric dryer | AppliancePartsPros.com
P.S. This dryer made by GE, not Whirlpool.
