Glen Tabor
#1 Posted : Wednesday, September 9, 2009 7:34:13 AM(UTC)
Glen Tabor
I am getting fiber of some type in my jets. Looks like it may be off a scrub brush. I havent put anything in there like it. I thought it might be off the impeller but looking at diagram that doesnt seem to be the case. What should I do?:D
#2 Posted : Wednesday, September 9, 2009 1:25:49 PM(UTC)
Very likely this is a limescale buildup. Can you see a white stuff inside the dishwasher?
If the answer is "Yes" then you can find some useful information in one of our previous posts: http://forum.appliancepartspros...g-element.html#post37989
Here are the breakdown diagrams for the Kitchen Aid dishwasher Model KUDI230B0
Whirlpool impeller/motor problem? (Dishwasher Repair)
by pjmayhew 6/5/2020 7:01:54 PM(UTC)
Bosch Impeller - How to Remove? (Dishwasher Repair)
by JCdiyGuy 10/2/2019 10:19:47 AM(UTC)
Dishes dirty after Whirlpool/Kenmore Impeller replacement - incorrecct part? (Dishwasher Repair)
by rrintala 11/25/2018 4:56:04 PM(UTC)
Can't remove impeller screw (Dishwasher Repair)
by DIY2309 10/6/2018 3:54:35 PM(UTC)
Can't loosen impeller part for kenmore dishwasher (Dishwasher Repair)
by rbhall52 9/5/2017 12:04:52 PM(UTC)
Maytag machine impeller/wash plate spins very fast (Washer Repair)
by Geo_hall 3/27/2017 9:14:56 PM(UTC)
Are impeller seal kits reliable? (Dishwasher Repair)
by kevin95630 1/4/2017 3:50:02 PM(UTC)
Screw on Maytag at impeller spinning unable to remove (Dishwasher Repair)
by coloradosurfer 9/30/2014 12:08:22 PM(UTC)
Replace Impeller/pump filer (Dishwasher Repair)
by pablack00 4/18/2014 4:54:21 AM(UTC)
Intermittent ratcheting type of noise from impeller/agitator area (Washer Repair)
by Turbobob 11/5/2013 3:25:24 PM(UTC)
How to Remove Impeller (Dishwasher Repair)
by Nocturnal1 3/11/2013 12:09:14 AM(UTC)
Lower drain impeller replacement (Dishwasher Repair)
by tiaric 12/19/2012 7:01:25 AM(UTC)
Unplug pump impeller (Dishwasher Repair)
by alanalan 10/23/2012 9:49:11 AM(UTC)
Maytag drain pump impeller broken (Washer Repair)
by wade busha 10/13/2012 4:58:49 PM(UTC)
Leak by impeller by pump housing (Dishwasher Repair)
by mtnbike86 9/7/2012 2:21:15 PM(UTC)
