mau397
#1 Posted : Sunday, May 6, 2012 2:38:20 PM(UTC)
mau397
i have a ge washer that is not spinning. i found the blinking light and it was blinking 6 times = rotor is locked
i can rotate the agitator and the unit will drain the water in the tub.
i was reading online and tried reseting the system. i did that and not the light just blinks which just means that is thinks its ok. i can rotate both pulleys and the belt is not broken. i checked the lid switch and it is working.
i checked for vac on the blue/black wires in a 2 pin connector that goes to the motor. i cant get to the other connector that has a red/white and i think black connector. so i'm getting power which means that motor is bad correct???
the online codes said that if the pulleys turn the motor needs to be replaced, is there any other way to verify this since the motor is $215???
thanks,
mark
#2 Posted : Monday, May 7, 2012 2:22:52 PM(UTC)
There are no any other reliable instrumental tests for the motor/inverter assembly. The error code, shown by the self diagnostic, and the tests you already did are leading to a bad motor/inverter. Also, if you'll order it from APP and it would not fix the problem, you can return it.
- The motor/inverter assembly Part number: WH20X10058
GE Washer not spinning (Washer Repair)
by zoobteach 8/29/2015 10:12:50 AM(UTC)
by atomicsynth 6/2/2015 10:36:31 PM(UTC)
GE washer not spinning any cycle (Washer Repair)
by j409 6/2/2014 7:44:19 AM(UTC)
GE Washer not Spinning (Washer Repair)
by jkomes 12/19/2013 6:52:43 PM(UTC)
GE washer not spinning out all the water (Washer Repair)
by sbryant73 11/16/2013 2:51:08 PM(UTC)
by Tigerhawk247 11/5/2013 7:14:29 PM(UTC)
by jschust 10/6/2013 9:17:23 AM(UTC)
GE washer not spinning (Washer Repair)
by dorlando 7/13/2013 6:06:17 PM(UTC)
by jlbyrnes3 4/8/2013 10:54:18 PM(UTC)
by JD0034 1/1/2013 5:13:24 PM(UTC)
GE Washer not spinning and smells strange (Washer Repair)
by greenfelt22 7/26/2011 6:26:28 AM(UTC)
GE Washer not spinning. Bad motor or transmission? (Washer Repair)
by MrJosh 6/17/2009 7:02:48 AM(UTC)
