rebel53
#1 Posted : Sunday, April 15, 2012 9:38:44 AM(UTC)
rebel53
freezer not freezing think defrost timer not working properly, had a similar problem before turned off and let sit for a day or two worked fine for a couple months, loaded with food and noticed not freezing
#2 Posted : Sunday, April 15, 2012 9:52:27 AM(UTC)
Replacement parts for Frigidaire FFU2064DW1 Frigidaire/freezer | AppliancePartsPros.com
First remove the evaporator cover in the freezer so you can see the coils.
Do not let them de-ice.
If yes.
Manually force a defrost cycle by turning the defrost timer cam (Item 23 in Section 3) till the fans and compressor turn off.
There is usually a hole in the cover to let you do this without taking anything apart.
Now check the defrost heater to see if it is on.
Be careful you do not want to burn your fingers.
If the heater is on then the timer needs replacing, re: it is probably stalling during it's rotation so is never getting into a defrost cycle.
If not on.
Unplug the unit.
Remove the wire for one side of the heating element (Item 14 in Section 3) from the wiring and measure it for continuity, usually around 20 ohms or so.
If the heater is OK
Remove one wire to the defrost thermostat (Item 20 in Section 3) and measure it, should be 0 ohms when frozen. Note that it opens just above freezing so must be frozen to check it. Also inspect it, if it is bulged at all replace it even if it measures OK.
If both the above are OK then odds are the defrost timer contacts are toast.
Best way to test this is a live test to see if you have 120 volts across the heater/defrost thermostat combo.
lg freezer not defrosting (Refrigerator & Freezer Repair)
by richardskg 1/13/2022 12:13:59 PM(UTC)
Whirlpool Refrigerator GS6NBEXRT01 Freezer not defrosting (Refrigerator & Freezer Repair)
Belarus Alexeyk 1/6/2020 12:04:41 PM(UTC)
Freezer Not Defrosting - Fan, Thermometer, Heater "okay" (Refrigerator & Freezer Repair)
Belarus frankla10 3/30/2017 2:41:44 AM(UTC)
Belarus kend64 8/13/2014 1:12:13 PM(UTC)
by poinzy82 8/15/2013 4:00:48 PM(UTC)
by RedStickBill3 8/28/2012 1:31:57 PM(UTC)
Freezer not defrosting coils (Refrigerator & Freezer Repair)
by srblan 8/7/2012 8:52:05 AM(UTC)
Freezer Not Defrosting, ICING UP Model ED2FHEXSB02 (Refrigerator & Freezer Repair)
by Microman66 7/6/2012 8:10:36 PM(UTC)
KitchenAid bottom freezer not defrosting (Refrigerator & Freezer Repair)
by Telicoman 6/23/2012 8:55:03 AM(UTC)
by peytond 2/22/2012 6:57:13 PM(UTC)
Whirlpool top freezer not defrosting (Refrigerator & Freezer Repair)
by frankla10 1/2/2012 5:11:32 PM(UTC)
Admiral refrigerator/top freezer not defrosting, and refrigerator getting warm (Refrigerator & Freezer Repair)
by 808BigShorty 1/7/2011 11:20:27 AM(UTC)
Freezer not Defrosting/Frig Side wWarm (Refrigerator & Freezer Repair)
by cajungirl 12/19/2010 9:18:06 PM(UTC)
Freezer not Defrosting (Refrigerator & Freezer Repair)
by Sam357 11/2/2010 1:53:27 PM(UTC)
by jd18 8/6/2010 6:35:03 PM(UTC)
