jd18
#1 Posted : Friday, August 6, 2010 6:35:03 PM(UTC)
jd18
Replaced defrost timer few weeks ago and seemed to be working fine.fridge section got warm again looked at coils in freezer section and are iced up again. tried to manually defrost by turning dfrost timer. shuts compressor but does not defrost colis and compressor kicks in again relatively quickly. also timer is making noise, could timer be defective already contacted parts companyfor replacement. any help would be appreciated
#2 Posted : Saturday, August 7, 2010 10:54:11 AM(UTC)
Replacement parts for FRIGIDAIRE FRS26ZGHW0 Frg(v3) / Refrigerator | AppliancePartsPros.com
Here is a tech sheet
http://manuals.frigidaire.com/prodinfo_pdf/Anderson/218909400.pdf
Looking at the wiring diagram and the picture in the parts, it looks like your defrost should come on for 30 minutes every 6 hours of compressor run time.
You did not say what troubleshooting you did to determine that the timer was your problem. If you just felt this was the most likely cause and replaced it then your problem may well be the defrost thermostat or the heater itself.
First remove the evaporator cover in the freezer so you can see the coils.
Do not let them de-ice.
If they are heavily iced/frosted over you have a defrost problem.
If yes.
Manually force a defrost cycle by turning the defrost timer cam till the fans and compressor turn off.
Now check the defrost heater to see if it is on.
Be careful you do not want to burn your fingers.
If the heater is on then the timer needs replacing, re: it is probably stalling during it's rotation so is never getting into a defrost cycle.
If not on.
Unplug the unit.
Remove the wire for one side of the heating element from the wiring and measure it for continuity, usually around 20 ohms or so.
If the heater is OK
Remove one wire to the defrost thermostat (Item in Section ) and measure it, should be 0 ohms when frozen. Note that it opens just above freezing so must be frozen to check it. Also inspect it, if it is bulged at all replace it even if it measures OK. They have been known to go intermittent.
If both the above are OK then odds are the defrost timer contacts are toast.
Best way to test this is a live test to see if you have 120 volts across the heater/defrost thermostat combo.
jd18
#3 Posted : Tuesday, August 10, 2010 5:09:04 PM(UTC)
jd18
Denman,
Thanks for the reply. I did trouble shoot prior to replacing timer. When forced old timer into defrost mode the heater worked and defrosted the coils. when I replaced the timer it was working fine on its own. I kept checking it for a few days before putting everything back together. Then coils froze over again and when turn timer dial to defrost it shuts compressor but heater does not turn on
#4 Posted : Wednesday, August 11, 2010 2:43:08 AM(UTC)
Odds are that the defrost thermostat has gone intermittent.
I would replace that if the heater still checks out OK.
Another possibility would be a bad connection to the heater/thermostat from the timer but I would go with replacing the the thermostat first.
lg freezer not defrosting (Refrigerator & Freezer Repair)
by richardskg 1/13/2022 12:13:59 PM(UTC)
Whirlpool Refrigerator GS6NBEXRT01 Freezer not defrosting (Refrigerator & Freezer Repair)
by Alexeyk 1/6/2020 12:04:41 PM(UTC)
Freezer Not Defrosting - Fan, Thermometer, Heater "okay" (Refrigerator & Freezer Repair)
by frankla10 3/30/2017 2:41:44 AM(UTC)
by kend64 8/13/2014 1:12:13 PM(UTC)
by poinzy82 8/15/2013 4:00:48 PM(UTC)
by RedStickBill3 8/28/2012 1:31:57 PM(UTC)
Freezer not defrosting coils (Refrigerator & Freezer Repair)
by srblan 8/7/2012 8:52:05 AM(UTC)
Freezer Not Defrosting, ICING UP Model ED2FHEXSB02 (Refrigerator & Freezer Repair)
by Microman66 7/6/2012 8:10:36 PM(UTC)
KitchenAid bottom freezer not defrosting (Refrigerator & Freezer Repair)
by Telicoman 6/23/2012 8:55:03 AM(UTC)
by rebel53 4/15/2012 9:38:44 AM(UTC)
by peytond 2/22/2012 6:57:13 PM(UTC)
Whirlpool top freezer not defrosting (Refrigerator & Freezer Repair)
by frankla10 1/2/2012 5:11:32 PM(UTC)
Admiral refrigerator/top freezer not defrosting, and refrigerator getting warm (Refrigerator & Freezer Repair)
by 808BigShorty 1/7/2011 11:20:27 AM(UTC)
Freezer not Defrosting/Frig Side wWarm (Refrigerator & Freezer Repair)
by cajungirl 12/19/2010 9:18:06 PM(UTC)
Freezer not Defrosting (Refrigerator & Freezer Repair)
by Sam357 11/2/2010 1:53:27 PM(UTC)
