Replacement parts for FRIGIDAIRE FRS26ZGHW0 Frg(v3) / Refrigerator | AppliancePartsPros.comHere is a tech sheet
http://manuals.frigidaire.com/prodinfo_pdf/Anderson/218909400.pdfLooking at the wiring diagram and the picture in the parts, it looks like your defrost should come on for 30 minutes every 6 hours of compressor run time.
You did not say what troubleshooting you did to determine that the timer was your problem. If you just felt this was the most likely cause and replaced it then your problem may well be the defrost thermostat or the heater itself.
First remove the evaporator cover in the freezer so you can see the coils.
Do not let them de-ice.
If they are heavily iced/frosted over you have a defrost problem.
If yes.
Manually force a defrost cycle by turning the defrost timer cam till the fans and compressor turn off.
Now check the defrost heater to see if it is on.
Be careful you do not want to burn your fingers.
If the heater is on then the timer needs replacing, re: it is probably stalling during it's rotation so is never getting into a defrost cycle.
If not on.
Unplug the unit.
Remove the wire for one side of the heating element from the wiring and measure it for continuity, usually around 20 ohms or so.
If the heater is OK
Remove one wire to the defrost thermostat (Item in Section ) and measure it, should be 0 ohms when frozen. Note that it opens just above freezing so must be frozen to check it. Also inspect it, if it is bulged at all replace it even if it measures OK. They have been known to go intermittent.
If both the above are OK then odds are the defrost timer contacts are toast.
Best way to test this is a live test to see if you have 120 volts across the heater/defrost thermostat combo.
