Charlie1076
#1 Posted : Wednesday, January 16, 2008 8:26:01 AM(UTC)
Charlie1076
My Dryer was not starting....I checked the Thermal Fuse....that was the problem...no continuity...I am replacing the Thermal Fuse.....my question is do I need to change the Thermostat Part Number: AP3131939 as well?
How do I check that Part Number AP3131939 Thermostat to see if that is the problem as well. How do I check the thermostat for Continuity? Which of the four wires should I pull off from the Thermostat and where should my OHM meter be touching to check the Continuity????
When replacing the Thermal Fuse do I need to also replace the Thermostat right below it?
Please help!
abbie
#2 Posted : Wednesday, January 16, 2008 12:57:49 PM(UTC)
abbie
If it,s the first time replacing the fuse all I would check would be the dryer vent. Make sure it is not plugged or kinked and that the air flow is good.
Guest (4)
Kenmore dryer problems after replace drum belt/idler pulley (Dryer Repair)
by Hspot 11/22/2020 12:41:02 PM(UTC)
Cabrio dryer problems (Dryer Repair)
by artsalena 1/19/2017 2:37:30 PM(UTC)
GE dryer problems (Dryer Repair)
by js072384 5/12/2012 9:15:49 PM(UTC)
Dryer Problems (Dryer Repair)
by smartin349 1/1/2012 6:35:54 AM(UTC)
by Mickey_951 10/1/2011 5:53:04 PM(UTC)
by Tsailor 3/4/2011 3:51:27 PM(UTC)
Dryer problems (Dryer Repair)
by Shoopes 11/16/2009 5:24:35 PM(UTC)
by talbot 11/2/2009 9:37:55 AM(UTC)
Asko condenser dryer problems (Dryer Repair)
by Marv Sumner 10/19/2009 11:05:38 AM(UTC)
Dryer problems mikeo (Dryer Repair)
by mikeo1899 8/4/2009 9:15:16 AM(UTC)
by berniefl 7/24/2009 6:13:21 AM(UTC)
Dryer problems HELP (Dryer Repair)
by MizzJessica 7/6/2009 10:39:42 PM(UTC)
by mbgrdido 3/24/2009 7:52:23 PM(UTC)
by janezucker 12/29/2008 9:36:33 AM(UTC)
Roper Dryer problems (Dryer Repair)
by b0001744 8/29/2008 9:38:02 AM(UTC)
