Charlie1076
#1 Posted : Wednesday, January 16, 2008 8:26:01 AM(UTC)
Charlie1076
My Dryer was not starting....I checked the Thermal Fuse....that was the problem...no continuity...I am replacing the Thermal Fuse.....my question is do I need to change the Thermostat Part Number: AP3131939 as well?
How do I check that Part Number AP3131939 Thermostat to see if that is the problem as well. How do I check the thermostat for Continuity? Which of the four wires should I pull off from the Thermostat and where should my OHM meter be touching to check the Continuity????
When replacing the Thermal Fuse do I need to also replace the Thermostat right below it?
Please help!
abbie
#2 Posted : Wednesday, January 16, 2008 12:57:49 PM(UTC)
abbie
If it,s the first time replacing the fuse all I would check would be the dryer vent. Make sure it is not plugged or kinked and that the air flow is good.
Kenmore dryer problems after replace drum belt/idler pulley (Dryer Repair)
by Hspot 11/22/2020 12:41:02 PM(UTC)
Cabrio dryer problems (Dryer Repair)
by artsalena 1/19/2017 2:37:30 PM(UTC)
GE dryer problems (Dryer Repair)
by js072384 5/12/2012 9:15:49 PM(UTC)
Dryer Problems (Dryer Repair)
by smartin349 1/1/2012 6:35:54 AM(UTC)
by Mickey_951 10/1/2011 5:53:04 PM(UTC)
by Tsailor 3/4/2011 3:51:27 PM(UTC)
Dryer problems (Dryer Repair)
by Shoopes 11/16/2009 5:24:35 PM(UTC)
by talbot 11/2/2009 9:37:55 AM(UTC)
Asko condenser dryer problems (Dryer Repair)
by Marv Sumner 10/19/2009 11:05:38 AM(UTC)
Dryer problems mikeo (Dryer Repair)
by mikeo1899 8/4/2009 9:15:16 AM(UTC)
by berniefl 7/24/2009 6:13:21 AM(UTC)
Dryer problems HELP (Dryer Repair)
by MizzJessica 7/6/2009 10:39:42 PM(UTC)
by mbgrdido 3/24/2009 7:52:23 PM(UTC)
by janezucker 12/29/2008 9:36:33 AM(UTC)
Roper Dryer problems (Dryer Repair)
by b0001744 8/29/2008 9:38:02 AM(UTC)
