ironmike61
#1 Posted : Thursday, March 15, 2012 11:00:15 AM(UTC)
ironmike61
Hello, last year my wife and I downsized to a smaller house. The house had a Bosch SHY56A05UC/14 dishwasher that was known not to be functional. So for the last year we have been hand washing everything. Anyway, I thought it might be time to look at repairing this if it isn't too expensive.
The problem I have is that the red power light does come on when turned on but nothing else. There is no display at all. I read where it may be an issue with the door switch but after removing the switch and doing a resistance test on the switch it is working fine. I then removed the control panel but cannot see any obvious physical burnt solder joints on the board. Is this board still the most likely culprit or do I need to look at something else?
Any suggestions would be appreciated.
#2 Posted : Thursday, March 15, 2012 2:24:20 PM(UTC)
Check if there is proper (about 120 VAC) voltage from the On-Off switch to the control module while the door is closed and the "On-Off" is in On position.
If the voltage reading is correct, replace the control module.
- The control module Part number: AP2834053
ironmike61
#3 Posted : Friday, March 16, 2012 3:33:16 PM(UTC)
ironmike61
Thanks Gene. I did check the voltage and yes the contol board is receiving power. I suspect you are right about being the board. Even though I still don't have any display if I wiggle the connector at the control board that is receiving the 120 volt from the door switch it starts to cycle on and off.
#4 Posted : Friday, March 16, 2012 4:10:09 PM(UTC)
Originally Posted by: ironmike61 Go to Quoted Post
...I did check the voltage and yes the contol board is receiving power...
The control board is the culprit. No doubts about it.
Whirlpool double oven RBD305PVS02 no display, no heat, lights work (Oven Repair (including Ranges and Cooktops))
by Guest 1/5/2022 7:05:37 AM(UTC)
Whirlpool Double Oven, RBD305PRS00, no display, oven dead (Oven Repair (including Ranges and Cooktops))
by steveg_nh 12/31/2021 7:23:33 AM(UTC)
No Display or Oven Light - GE Monogram ZGP304NR4SS (Oven Repair (including Ranges and Cooktops))
by Furgus 8/22/2021 10:11:09 AM(UTC)
GE Profile PSRS6PGZADSS No Lights, No Display Panel (Refrigerator & Freezer Repair)
by ablundon 5/5/2021 10:43:50 AM(UTC)
Fridge not working, No cooling, and no display (Refrigerator & Freezer Repair)
by thepr1nter 1/13/2021 8:22:08 AM(UTC)
Thermador double oven no display (Oven Repair (including Ranges and Cooktops))
by daiwa0411 10/8/2020 7:12:03 AM(UTC)
No Display, but Oven works and buttons beep (Oven Repair (including Ranges and Cooktops))
by kevinlampert 10/5/2020 2:11:56 PM(UTC)
Samsung DV42H5200EW/A3 No Display (Dryer Repair)
by caveman61 7/18/2020 7:28:59 AM(UTC)
Whirlpool Duet-No Display or Button function (Dryer Repair)
by floatinghead 6/8/2019 6:55:48 AM(UTC)
Not heating/No Display until burner switch turned on (Oven Repair (including Ranges and Cooktops))
by MattoxL 2/7/2017 6:16:27 PM(UTC)
Jenn Air Combination Wall Oven - NO Display?? (Oven Repair (including Ranges and Cooktops))
by jtharmon 12/19/2016 5:06:52 AM(UTC)
No display (Oven Repair (including Ranges and Cooktops))
by bartbill 11/16/2016 10:51:46 PM(UTC)
GE Refrigerator - No display indicator and cooling (Refrigerator & Freezer Repair)
by coolvir 11/15/2015 6:49:44 PM(UTC)
No Display (Oven Repair (including Ranges and Cooktops))
by shaneast1 10/4/2015 8:08:29 AM(UTC)
by gschvach 9/20/2015 5:57:03 AM(UTC)
