caveman61
#1 Posted : Saturday, July 18, 2020 7:28:59 AM(UTC)
caveman61
United States
Our Samsung was in storage for one year, after setting up and leveling the dryer worked great for 5-6 loads. At the end of the 7th load the dryer would not start and the display is blank.
Found your site and the highest percentage repair was replacing the Thermal Fuse. After replacing no change. Doing T&D I have tested [OHM] all switches, fuses and heating element, no issues. Checked power to dryer, good. I am unable, to test the control panel...is this a symptom of the control panel [AP5916791] malfunctioning?
It seems that most other failures, i.e. motor, don't stop the control panel to display...
I know troubleshooting over an email is next to impossible but what component would fail that would cause no more display? How to test?
Please over assistance. Thanks
