MattoxL
#1 Posted : Tuesday, February 7, 2017 6:16:27 PM(UTC)
MattoxL
Ok, I need help.. :confused: Problem started with oven, didn't seem like it was working quite right, wasn't positive just figured heating element was going out. Next thing I know one of the burners stopped getting to boiling temperature. It was hot but not as should be. Then the clock started blinking and I noticed none of the burners were getting hot and the display stopped working unless I had one of the burner switches on. So now none of the burners heat at all, the oven doesn't heat at all and the display only displays if I have a burner switch turned on?? Any help would be greatly appreciated!! Thank you..
MattoxL
#2 Posted : Saturday, February 11, 2017 1:56:38 AM(UTC)
MattoxL
Tested the 220 outlet and everything is working fine there.. Thinking of maybe getting a new control board??
