This Kenmore Elite dishwasher Mod#665.15933000 below three thrmo fuses when it reaches the end of the washing cycle. I think the thermister is no good when I test it for continuity.or should I test it while it is in hot water.
Originally Posted by: Moe147  This Kenmore Elite dishwasher Mod#665.15933000 below three thrmo fuses when it reaches the end of the washing cycle. I think the thermister is no good when I test it for continuity.or should I test it while it is in hot water. Moe, Is this the thermal fuse you're discussing Part number: AP3178588
If so, You are installing the complete assembly, including the wires, and following the instructions to a "tee". You can test the thermistor at room temperature, it should have a resistance of 48 to 52 K ohms. and the limit thermostat should have a "closed" circuit below 170 dgrs.F. You will need to check and make sure you have a minimum voltage of 110 VAC"under a load" with the motor running or heater on. Thanks and Good Luck, :) :) :)
