Moe147
#1 Posted : Wednesday, March 7, 2012 8:59:58 AM(UTC)
Moe147
This Kenmore Elite dishwasher Mod#665.15933000 below three thrmo fuses when it reaches the end of the washing cycle. I think the thermister is no good when I test it for continuity.or should I test it while it is in hot water.
Joe / APP Team
#2 Posted : Wednesday, March 7, 2012 12:30:28 PM(UTC)
Joe / APP Team
Moe,
Is this the thermal fuse you're discussing Part number: AP3178588
If so, You are installing the complete assembly, including the wires, and following the instructions to a "tee".
You can test the thermistor at room temperature, it should have a resistance of 48 to 52 K ohms. and the limit thermostat should have a "closed" circuit below 170 dgrs.F.
You will need to check and make sure you have a minimum voltage of 110 VAC"under a load" with the motor running or heater on.
Thanks and Good Luck,
Kenmore Elite Dishwasher Problem (Dishwasher Repair)
by AndyH01 3/31/2022 3:33:31 AM(UTC)
No power to control panel Kenmore Elite dishwasher model 665.12793k311 (Garbage Disposer Repair)
by John Boof 2/2/2022 6:56:51 PM(UTC)
Kenmore Elite Dishwasher Tech Sheet needed (Dishwasher Repair)
by Recon2it 3/15/2019 3:06:42 PM(UTC)
Kenmore Elite dishwasher 665.13112K700 blows thermal fuse (Dishwasher Repair)
by rrsteven 10/31/2018 9:02:16 PM(UTC)
Kenmore Elite Dishwasher 665.16039403 Wash & Pump Problems (Dishwasher Repair)
by Maico18 7/24/2018 10:35:33 AM(UTC)
Kenmore Elite dishwasher (Dishwasher Repair)
by drewster 11/1/2016 4:26:55 PM(UTC)
Kenmore Elite Dishwasher diverter installation (Dishwasher Repair)
by fasta6 11/13/2014 6:26:52 AM(UTC)
Kenmore elite dishwasher (Dishwasher Repair)
by lwarden 2/11/2014 8:31:48 AM(UTC)
Kenmore Elite Dishwasher wont start (Dishwasher Repair)
by jlewis2407 9/22/2013 3:54:19 PM(UTC)
Kenmore Elite Dishwasher - stuck - green light flashing (Dishwasher Repair)
by jfwilliams3 4/28/2013 7:52:01 PM(UTC)
Kenmore Elite Dishwasher blowing fuses (Dishwasher Repair)
by dennis728 2/26/2013 2:20:25 PM(UTC)
kenmore elite dishwasher (Dishwasher Repair)
by beaumart@plateautel.net 1/1/2013 2:40:43 PM(UTC)
Kenmore Elite Dishwasher Stopped Mid-Cycle (Washer Repair)
by regpum 11/13/2012 6:34:23 PM(UTC)
Kenmore Elite Dishwasher (Dishwasher Repair)
by rlarson 3/28/2012 11:31:27 PM(UTC)
Kenmore Elite Dishwasher Won't Start (Dishwasher Repair)
by sstanley 2/18/2012 10:38:58 PM(UTC)
