rlarson
#1 Posted : 13 years ago
rlarson
Hello all. I am have a bad sound on a normal cycle at like 45 minutes. Its like a loud grinding sound. i have take it apart as far as the chopper assembly. and cleaned out some gunk that was in there also. I happen usually at the 45 mark when i think it does a big drain of the water. cause when you start it like around 70 or so it does a drain there. it doesn't do that noise at that time. But at 45 minutes its making that loud grinding sound. Should i replace the drain motor or is there any other test i can do to fix this. Thanks.
ApplianceJunk
#2 Posted : 13 years ago
ApplianceJunk
When it's making the noise I would unplug the wire harness that goes to the drain motor to see if the noise stops.
If the noise stops then you know it's the drain pump making the noise.
I replace a lot of these little drain pumps because they get noisy.
Kenmore Elite Dishwasher Problem (Dishwasher Repair)
by AndyH01 3 years ago
No power to control panel Kenmore Elite dishwasher model 665.12793k311 (Garbage Disposer Repair)
by John Boof 3 years ago
Kenmore Elite Dishwasher Tech Sheet needed (Dishwasher Repair)
by Recon2it 6 years ago
Kenmore Elite dishwasher 665.13112K700 blows thermal fuse (Dishwasher Repair)
by rrsteven 6 years ago
Kenmore Elite Dishwasher 665.16039403 Wash & Pump Problems (Dishwasher Repair)
by Maico18 7 years ago
Kenmore Elite dishwasher (Dishwasher Repair)
by drewster 8 years ago
Kenmore Elite Dishwasher diverter installation (Dishwasher Repair)
by fasta6 10 years ago
Kenmore elite dishwasher (Dishwasher Repair)
by lwarden 11 years ago
Kenmore Elite Dishwasher wont start (Dishwasher Repair)
by jlewis2407 12 years ago
Kenmore Elite Dishwasher - stuck - green light flashing (Dishwasher Repair)
by jfwilliams3 12 years ago
Kenmore Elite Dishwasher blowing fuses (Dishwasher Repair)
by dennis728 12 years ago
kenmore elite dishwasher (Dishwasher Repair)
by beaumart@plateautel.net 12 years ago
Kenmore Elite Dishwasher Stopped Mid-Cycle (Washer Repair)
by regpum 12 years ago
Kenmore Elite Dishwasher (Dishwasher Repair)
by Moe147 13 years ago
Kenmore Elite Dishwasher Won't Start (Dishwasher Repair)
by sstanley 13 years ago
