Greetings,
Thanks in advance for any help to pin point my exact problem. My dishwasher cycle begins and it starts filling up with water. After 20-40 secs it tries to cycle to the next step and can't. you can hear a pump or something water to engage but it cant. Spry arm are not clogged. It gets water, it fills up an it will go though the cycles in time. Water pumps out. Not sure whats needs to be replaced. I replaced the water pump about to years ago water wouldn't drain. Now this. Thanks
Groups: Expert
665.13123k702
Yeah sounds like the motor wants to engage but can't. I want to say I have heard the motor sounding a little off leading up to this point. After doing some research and watching some video's I see that the circulator pump and motor are all in one. I am thinking about replacing it. I will check it first with a volt meter. As for my board, well you never know but I haven't seen any AOC's with the lights. Everything looks good. Thoughts ?
Well I did replace the motor. Job took about 2.5 hours that includes cleaning up. Works like a charm. Part cost me about $180.00 bucks. A big savings overall.
