Moe147
#1 Posted : 13 years ago
Moe147
This Kenmore Elite dishwasher Mod#665.15933000 below three thrmo fuses when it reaches the end of the washing cycle. I think the thermister is no good when I test it for continuity.or should I test it while it is in hot water.
Joe / APP Team
#2 Posted : 13 years ago
Joe / APP Team
Moe,
Is this the thermal fuse you're discussing Part number: AP3178588
If so, You are installing the complete assembly, including the wires, and following the instructions to a "tee".
You can test the thermistor at room temperature, it should have a resistance of 48 to 52 K ohms. and the limit thermostat should have a "closed" circuit below 170 dgrs.F.
You will need to check and make sure you have a minimum voltage of 110 VAC"under a load" with the motor running or heater on.
Thanks and Good Luck,
Kenmore Elite Dishwasher Problem (Dishwasher Repair)
by AndyH01 3 years ago
No power to control panel Kenmore Elite dishwasher model 665.12793k311 (Garbage Disposer Repair)
by John Boof 3 years ago
Kenmore Elite Dishwasher Tech Sheet needed (Dishwasher Repair)
by Recon2it 6 years ago
Kenmore Elite dishwasher 665.13112K700 blows thermal fuse (Dishwasher Repair)
by rrsteven 6 years ago
Kenmore Elite Dishwasher 665.16039403 Wash & Pump Problems (Dishwasher Repair)
by Maico18 7 years ago
Kenmore Elite dishwasher (Dishwasher Repair)
by drewster 8 years ago
Kenmore Elite Dishwasher diverter installation (Dishwasher Repair)
by fasta6 10 years ago
Kenmore elite dishwasher (Dishwasher Repair)
by lwarden 11 years ago
Kenmore Elite Dishwasher wont start (Dishwasher Repair)
by jlewis2407 12 years ago
Kenmore Elite Dishwasher - stuck - green light flashing (Dishwasher Repair)
by jfwilliams3 12 years ago
Kenmore Elite Dishwasher blowing fuses (Dishwasher Repair)
by dennis728 12 years ago
kenmore elite dishwasher (Dishwasher Repair)
by beaumart@plateautel.net 12 years ago
Kenmore Elite Dishwasher Stopped Mid-Cycle (Washer Repair)
by regpum 12 years ago
Kenmore Elite Dishwasher (Dishwasher Repair)
by rlarson 13 years ago
Kenmore Elite Dishwasher Won't Start (Dishwasher Repair)
by sstanley 13 years ago
