Daz62158
#1 Posted : Friday, July 31, 2009 3:12:45 PM(UTC)
Daz62158
Serial #S9902225570 120/240 AMP60
The dryer runs and heats but makes a thumping sound when the barrel of the dryer turns.
sidfink43
#2 Posted : Sunday, August 2, 2009 6:09:41 AM(UTC)
sidfink43
As you probably noticed if you reviewed posting on this Forum (and others) noises are hard for us to diagnose because we are not there to listen to them.
From your description, it seems like the rollers are the likely source of the problem. Try to listen to the location of the thumping, and if it is in the back replace the rollers (not an expensive part) and see if that does not solve the problem.
Good luck.
Speed Queen gas dryer Model SDG809WF (Dryer Repair)
by Guest 6/3/2024 11:05:10 AM(UTC)
Speed Queen shaft wear (Washer Repair)
by fredgilb 4/29/2024 3:11:05 PM(UTC)
Speed Queen top load washer model AWN412SP111TW01 (Washer Repair)
by Guest 4/28/2024 6:36:53 PM(UTC)
Speed Queen electric dryer model LES17AWF (Dryer Repair)
by Guest 3/5/2024 10:42:09 AM(UTC)
Speed Queen Washer makes random squeaking noise (Washer Repair)
by Guest 2/10/2024 7:29:00 AM(UTC)
Speed Queen top load washer model AWNE82SP113TW01 (Washer Repair)
by Guest 2/2/2024 10:12:50 AM(UTC)
Speed Queen top load washer modelAWN542SP111TW01 (Washer Repair)
by Guest 1/27/2024 10:43:32 AM(UTC)
Speed Queen top load washer model AWN542SP111TW01 (Washer Repair)
by Guest 1/13/2024 1:28:32 AM(UTC)
Speed Queen top load washer (Washer Repair)
by Guest 12/24/2023 4:29:03 AM(UTC)
by Guest 12/23/2023 3:02:14 AM(UTC)
Speed Queen top load washer typical model AWNE82SP113 (Dryer Repair)
by Guest 12/1/2023 8:26:13 AM(UTC)
Speed Queen electric dryer model ADE3LRG8171TWoi (Dryer Repair)
by Guest 11/26/2023 2:53:33 AM(UTC)
Speed Queen top load commercial coin type washer model SWT121WM (Washer Repair)
by Guest 11/11/2023 7:24:23 AM(UTC)
Speed Queen top load washer model AWS17NW (Washer Repair)
by Guest 10/16/2023 11:23:35 AM(UTC)
Alternate T-stat for Speed Queen gas dryer (Dryer Repair)
by Guest 10/14/2023 12:59:47 PM(UTC)
