The washer went out suddenly on a heavy load. I pulled off the front and the idler pulley, bearing and pin were laying separately in the bottom. Belt OK. Looking closely at the idler pulley I can see a crack in the side. From the top I can turn the agitator CCW easily. CW requires I first turn ccw to a check and then turn CW. The tub moves with the agitator in either direction. Motor works. Is this a bad tranny?
Does this sound like a reasonable repair job? Or go for a new machine.
If a new one, any recommendations? (Having a bad back, wife needs a top load. I've looked at some reviews of newer machines and have seen a lot of bad reviews, hence thinking of trying to get a used older model.)
What is the complete model number of the washer?
The plate with this info (on top of control panel) is faded out. It was made in 1993, is extra-large capacity, 3/4 hp motor. Never a problem til now.
Unfortunately without correct model number we are not able to find correct part numbers as well as break down diagrams. Guessing is not the way I would like to go.
Regarding a new washer I would recommend a top load machine made by Whirlpool without any electronics. Such washer, depends on capacity, can cost you between $350 to $500.
