My washer does not agitate or spin. It fills, progresses through the cycles, and drains, but the motor never turns on. The motor seems to be fine- it doesn't hum, or smell, and it spins freely when I turn it by hand. The blinking light code said the motor was stuck (6 blinks), but the motor is not stuck. I reset the washer (plug it back in and lift door 6 times) and the LED light now is blinking that operation is normal. I have also checked the lid switch, the pressure switch, and the fuse in the wiring harness. All of them are fine. All the lights on the control board work as well. I do not see any loose wires or burnt-out spots. I can not find anything wrong anywhere, but the motor never turns on. Any ideas? Thanks!!
Did you ever figure out what was wrong. Mine is doing the same thing. Any suggestions would help! Thanks in advance!
