resloan
#1 Posted : Monday, July 27, 2009 11:52:28 AM(UTC)
resloan
The washer went out suddenly on a heavy load. I pulled off the front and the idler pulley, bearing and pin were laying separately in the bottom. Belt OK. Looking closely at the idler pulley I can see a crack in the side. From the top I can turn the agitator CCW easily. CW requires I first turn ccw to a check and then turn CW. The tub moves with the agitator in either direction. Motor works. Is this a bad tranny?
Does this sound like a reasonable repair job? Or go for a new machine.
If a new one, any recommendations? (Having a bad back, wife needs a top load. I've looked at some reviews of newer machines and have seen a lot of bad reviews, hence thinking of trying to get a used older model.)
#2 Posted : Tuesday, July 28, 2009 11:52:55 AM(UTC)
What is the complete model number of the washer?
resloan
#3 Posted : Tuesday, July 28, 2009 12:10:13 PM(UTC)
resloan
The plate with this info (on top of control panel) is faded out. It was made in 1993, is extra-large capacity, 3/4 hp motor. Never a problem til now.
#4 Posted : Tuesday, July 28, 2009 7:37:25 PM(UTC)
Unfortunately without correct model number we are not able to find correct part numbers as well as break down diagrams. Guessing is not the way I would like to go.
Regarding a new washer I would recommend a top load machine made by Whirlpool without any electronics. Such washer, depends on capacity, can cost you between $350 to $500.
Guest (4)
GE washer doesn't agitate or spin (Washer Repair)
by natestiles 8/25/2016 7:13:45 PM(UTC)
GE washer doesn't agitate or spin consistently; transmission warm (Washer Repair)
by clepple 4/13/2014 3:43:17 PM(UTC)
by czy6ltlft 1/23/2010 5:21:16 PM(UTC)
GE Washer Doesn't Agitate or Spin!!! (Washer Repair)
by Pewterwssicc 9/28/2009 8:51:44 AM(UTC)
Washer Doesn't Agitate Or Spin (Washer Repair)
by upvacman 9/12/2009 8:32:55 PM(UTC)
