walberts
#1 Posted : 16 years ago
walberts
Our dishwasher is stuck in the drain cycle. no amount of button pushing seems to change anything.
Is there a way to override the command it is stuck in? If so, and if the situation happens again, what is the solution to the problem?
walberts
#2 Posted : 16 years ago
The first thing I would do is remove the toe panel and check for water in the base. The model number you posted does not come up. Verify and repost it.
foxfire
#3 Posted : 16 years ago
foxfire
I had the same problem with my dishwasher (Bosch, SHE 45M). My solution was to cancel and change the cycle. My manual was confusing because it described the process, and had a diagram for another model dishwasher which did not match mine.
On my dishwasher, there is a line drawn which says "Cancel/Reset." The line ends with dots under the "Power Scrub Plus" button and the "Regular Wash" button. I pressed both buttons at the same time and held them for 3-4 seconds, and the diswasher begin clearing the drain cycle. I was able to cut off the dishwasher and then re-start it with no problem. Hope this helps.
Ken
GE Washer stuck in drain cycle won't spin without manual start (Washer Repair)
by 7sarajoy 10 years ago
Whirlpool Dishwasher gets stuck in drain cycle (Dishwasher Repair)
by joelib92 12 years ago
Amana Frontload Washer Stuck in Drain Cycle (Washer Repair)
by txpony 12 years ago
General Electric Front load washer stuck in drain cycle (Washer Repair)
by Jasonkmol 14 years ago
Bosch Stuck in Drain Cycle; even with door open (Dishwasher Repair)
by toungetwster 15 years ago
by revving 17 years ago
Whirlpool Duet Sport washer seems stuck in drain cycle (Washer Repair)
by luistorres 17 years ago
