walberts
#1 Posted : Monday, July 27, 2009 4:32:34 AM(UTC)
walberts
Our dishwasher is stuck in the drain cycle. no amount of button pushing seems to change anything.
Is there a way to override the command it is stuck in? If so, and if the situation happens again, what is the solution to the problem?
walberts
#2 Posted : Monday, July 27, 2009 5:16:09 PM(UTC)
The first thing I would do is remove the toe panel and check for water in the base. The model number you posted does not come up. Verify and repost it.
foxfire
#3 Posted : Sunday, August 2, 2009 2:23:46 PM(UTC)
foxfire
I had the same problem with my dishwasher (Bosch, SHE 45M). My solution was to cancel and change the cycle. My manual was confusing because it described the process, and had a diagram for another model dishwasher which did not match mine.
On my dishwasher, there is a line drawn which says "Cancel/Reset." The line ends with dots under the "Power Scrub Plus" button and the "Regular Wash" button. I pressed both buttons at the same time and held them for 3-4 seconds, and the diswasher begin clearing the drain cycle. I was able to cut off the dishwasher and then re-start it with no problem. Hope this helps.
Ken
GE Washer stuck in drain cycle won't spin without manual start (Washer Repair)
by 7sarajoy 12/28/2014 4:45:33 PM(UTC)
Whirlpool Dishwasher gets stuck in drain cycle (Dishwasher Repair)
by joelib92 4/26/2013 5:12:15 AM(UTC)
Amana Frontload Washer Stuck in Drain Cycle (Washer Repair)
by txpony 10/23/2012 6:54:45 PM(UTC)
General Electric Front load washer stuck in drain cycle (Washer Repair)
by Jasonkmol 6/7/2011 8:34:56 AM(UTC)
Bosch Stuck in Drain Cycle; even with door open (Dishwasher Repair)
by toungetwster 3/10/2010 6:16:02 PM(UTC)
by revving 6/17/2008 6:04:03 AM(UTC)
Whirlpool Duet Sport washer seems stuck in drain cycle (Washer Repair)
by luistorres 5/29/2008 11:31:23 AM(UTC)
