My dishwasher is leaking, it is really wet on the bottom of the body valve and check assembly. Do these go bad and start to leak or do I have a leak somewhere else?
First Check See How Big the Leakage..if it is Bigger than better call the Support to replace it..Otherwise See if some nuts or bolts are not loose..
