jobHunter
#1 Posted : Wednesday, July 22, 2009 9:14:21 PM(UTC)
jobHunter
Hello,
Last week, there was a lot of water on the freezer side; filled the bottom & out the door on the floor too. I wasn't sure of the cause, but since then, the ice maker stopped working. The fill hose is not clogged. How do I determine if it is the valve or the ice maker unit?
woodchuckie
#2 Posted : Thursday, July 23, 2009 5:54:36 AM(UTC)
woodchuckie
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water problem could be: Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Whirlpool Model WRS588FIHZ00 Ice Maker Stopped Working (Refrigerator & Freezer Repair)
by roma1625 7/23/2022 4:39:02 AM(UTC)
GE Ice Maker Stopped Working (Refrigerator & Freezer Repair)
by Jyet2001 4/22/2016 1:12:45 PM(UTC)
Ice maker stopped working... (Refrigerator & Freezer Repair)
by Steelwheels1 4/6/2015 3:51:42 AM(UTC)
Ice maker stopped working on Kitchenaid (Refrigerator & Freezer Repair)
by schroederius 3/20/2013 9:23:17 AM(UTC)
by ACHASG 4/23/2012 8:43:17 AM(UTC)
Ice maker stopped working (Refrigerator & Freezer Repair)
by Cindy Schneider 2/13/2012 10:54:21 AM(UTC)
by wrexpert 2/15/2011 5:23:29 PM(UTC)
Control Panel, Ice Maker Stopped Working (Refrigerator & Freezer Repair)
by jrymski 2/13/2011 6:44:09 PM(UTC)
Ice maker stopped working. (Refrigerator & Freezer Repair)
by HomerH209 11/9/2010 10:50:59 AM(UTC)
Amana Ice Maker Stopped Working (Refrigerator & Freezer Repair)
by smaggard 9/27/2010 1:40:00 PM(UTC)
Maytag French Door ice maker stopped working (Refrigerator & Freezer Repair)
by kayken1010 8/3/2010 2:26:40 AM(UTC)
by dmkimm 7/21/2010 7:21:06 AM(UTC)
Kitchenaid side by side ice maker stopped working (Refrigerator & Freezer Repair)
by aloubo 2/19/2010 3:52:41 AM(UTC)
ice maker stopped working - kenmore elite side by side (Refrigerator & Freezer Repair)
by foobydoo 1/26/2010 1:12:14 PM(UTC)
GE Adora Fridge: Ice Maker stopped working. (Refrigerator & Freezer Repair)
by lighthouse832 1/7/2010 12:50:11 PM(UTC)
